Results 1 to 10 of 12
Thread: Starvision VGA. Daytime pictures. 56k beware.
    Aug 2003
    Milwaukee
    Well just finished installing the carpc and here are the results.
    Im very happy with the brightness. I actually had to lower it because it was too bright. As some of you have mentioned there is a bit of that yellow but I can fix that with the videocard. I also gota tell ya that the 250 dc-dc psu I bought is also amazing. No feedback at all. Sound is crystal clear. Even with the onboard audio. Touchscreen is excelent. Very responsive. With the results iv seen, i wouldnt mind recomending this screen to anyone. Unless my standards are too low. But you folks with the xenarcs and lilliputs should know better than me. So there ya go. Ill have more pics of my setup when everything is back in place and wires are tucked away nice and all.
    Aug 2003
    How do you fix the yellowing with the video card/software settings? I tried but gave up..
    Dec 2003
    looks good. is the light on the screen from the sun? what about some angle shots? and how do you compare the brightness to say a laptop or home lcd monitor?
    sq geek, in your display properties setting, and in the advanced setting, most vga monitor allow you to adjust colors and color temperature.
    if you dont see it, try to upgrade to the newest manufacture driver.
    Newbie Providence's Avatar
    Feb 2004
    Dallas, TX
    Arrow
    To fix the yellowing, go into Display Properties->advanced-> color
    There should be a diagonal line that you can move about to fix any color that the screen stays on.
    Providence is borne on the breath of prophecy.
    P4 2.66 | 1024 MB PC3200 | 4x Memorex DVD+RW | Memorex 52x24x52 CDRW | 200 and 60 GB HDDs | Antec 400W PSU
    Constant Bitrate ccblanket's Avatar
    Sep 2003
    SF Bay Area
    Zijester, do you power the monitor from the psu or the car's 12V (lighter?)
    Aug 2003
    Quote Originally Posted by Providence
    OK, thanks..
    But which way to you move it? Away from "yellow" ?
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    nice! I'm curious what kind of car is that in?
    Constant Bitrate spectrrr's Avatar
    Jan 2004
    Dayton, OH / Cambridge, MA
    Quote Originally Posted by sq_geek
    OK, thanks..
    whatever works
    2000 Jeep Cherokee
    -CarPC: [»»»»»_____]50% complete
    -planning done, still need a few parts
    -In-dash motorized VGA is finally out, need $$$
    -Need to replace factory HU
    Aug 2003
    Milwaukee
    93 mazda mx6 That glare in the last picture is from the flash. Forget to shut it off.
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    Another MX6 - excellent. That fascia bit your screen will be hiding behind - does that go all the way over over the dash to the door? Any tips for how to remove it? It's a big piece, and looks like an expensive bit to break :-)
    C!
    [edit] Oh - where are your airconditioning controls now?
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
  1. Starvision 7" VGA touchscreen pictures/review
    By NoPistonPC in forum LCD/Display
    Last Post: 08-31-2004, 04:26 AM
  2. VGA cable problem on DWW-7VGA, need pictures
    By OzPaddy in forum LCD/Display
    Last Post: 03-16-2004, 02:34 PM
