burning the cd is fine. and I always use a stylus to calibrate. Usually its very accurate.
I have the 7" lilliput touchscreen and after loading the drivers and software am having a hard time configuring it to actually use touchscreen. Do i have to use the stylus that came with it? How do you configure this properly so it doesn't rely on the mouse. Thanks.
also, the CD the drivers came on was a mini-disc and i re-burned it to a full disk so that there would be no complications when using my slotload dvd-rom, do you think this could have caused a problem? Should i reinstall the drivers and utilities?
Mine needs to be updated.
i just don't get any touchscreen response period....like i haven't installed it. I am not sure exactly how to configure the settings ....any advice?
you mean once you install the TS program and plug in the usb cable you dont see the touchscreen recognized?
dont use the drivers that came with the cd, there are some from http://www.egalax.com.tw/Download.htm that work well i believe
I had the same issue when I first got my screen. I found that I was clashing with another device on my system. For me it was my Bluetooth USB device. I had to unplug the device AND remove the drivers before the install of the touch screen was successfull. After that I was able to re-install the Bluetooth device.
My advise would be to remove as many external devices as you can and then try to install the screen. My guess is it was trying to install and use a restricted port range which was already in use. The bluetooth device appeared to be a little more forgiving on install.
I think I may have the same problem, no touchscreen at all even though xp appears to have installed it correctly.
I have just been inside the thing to see if there was anything loose with no joy, have any of the other posters with this problem got anywhere?
....Yes, I know it has a stupid name, those crazy Japanese!
hopefully i do not need to open mine upOriginally Posted by mp3oplecarrier
the only thing i can think is that when setting up the drivers i do recall noticing that the installation for the USB failed (or needed to first be connected to the net...possibly to register my XP copy which i haven't done yet). If the USB hasn't been set up yet (or correctly) then that could be my problem right?
these drivers are for 9x/ME though...still gonna work on mine?Originally Posted by Grayscale
