Results 1 to 7 of 7
Thread: Oh crap.. Does this appear like a dead LCD?
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    Well after running nicely for a few weeks, tonight all i get is a blank white screen. Solid. Tried a different video card, the same. Hooked it up to the laptop, still white and very, very blank.. OSD do not show up as well.
    It is obviously getting some signal since when i disconnect the cable the screen becomes black, but when i hook it up, it goes to blank white
    I am running this via a 6" VGA extension cable, but there is nothing visually wrong with the cable/joints.
    And yep, no POST, no boot up, nothing. Blank and white. solid. Help!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If no POST, check/reseat RAM and Video card.
    Try to connect the small PC speaker (one attach to the desktop case). Before/during POST, count the beep. One short beep mean good. If more than one check mobo manual for what the hell those beep mean.
    PC still boot with or without monitor (dead or a live).
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    Actually the actual pc boots and all. Just nothing on the screen, including post so i know it's not a resolution/refresh rate issue. I also tried it with another computer; still the same. I haven't powered it on in about 4 days and last time i had it on and off it was working perfectly. Perhaps something got knocked off inside?
    Nov 2003
    Quote Originally Posted by cdm
    What kind of monitor it's?
    Lilliput? xenarc? or what?
    this happened to also but it was the signal LCD ribbon cable that was loose. I have a lilliput
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    Since it gave me insomnia, i took it out of the car (ugh) and brought it upstairs.. now it won't even power on. Nada. Dead. nothing. lifeless.
    WTF? every time i try to turn it on its something different. ideas before i throw it out?
    just thought i would update that as of 230am it appears there is no power coming to it or it simply refuses to turn on. So i went from a blank screen to a nothing without doing anything.
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    Quote Originally Posted by CDesigns
    As far as i know, it is assembled by MMI (http://www.mmidisplaysystems.com/) using 3M parts.
    It is a 10.4" with serial touch screen. actual image of offending unit below.
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    Ok i took it apart today and tested it. backlight appears to operate but there is no power going to/through the controller whatsoever short of the 12v jack which is built into the controller itself (along with the osd buttons).
    The LCD is an and10c273-hb (300nits, 800x640 one), with a 3m dynapro resistive touch screen ran by some god awfull controller which now appears dead.
    I have emailed earth lcd to see if they have a compatible one, but really, does this appear like a controller issue or an electrical short (they are both on the same board apparently)?
    sigh... ever since the first screw this project has been nothing but a money pit and headaches.
    I would consider a lilliput mounted where my GPS is now, but with the array of issues they have and besides, once you've gone 10.4, you don't want to go back
  1. Is my Sony PSOne LCD dead on arrival?
    By nickis in forum LCD/Display
    Last Post: 01-28-2004, 06:56 PM
  2. LCD is dead. How why what can I do?
    By ofthedove in forum LCD/Display
    Last Post: 10-08-2003, 12:09 PM
  3. lcd datasheet help
    By oddcomp in forum LCD/Display
    Last Post: 11-08-2002, 11:24 AM
  4. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
  5. Why does compositve video out from a computer look like crap on an LCD?
    By manifesto in forum General Hardware Discussion
    Last Post: 02-14-2001, 03:19 AM
