excellent work making me rethink my design and possibly redo the install.
If you haven't seen it already, there is a great writeup on installing your Lilliput in a TM-701L housing here:
Writeup Lilliput installation in TM-701L housing
This is a description of what I did beyond that.
First off I did the indash conversion like everyone else, and the coyote auto-on mod.
Then I replaced all of the cables from the LCD through the housing with one ribbon cable, and added a nice little quick connect in the LCD housing for when I have to take it apart.
Ribbon Cable Outside Housing
Ribbon Cable Inside Housing
Close up of ribbon cable quick connect female side inside housing
Close up of ribbon cable quick connect male side inside housing
Ribbon cable coming out of the back of the LCD
After all that ribbon cable stuff, I added a rocker switch to make it so the LCD only gets power when it is pulled out of the housing.
The rocker switch from radio shack
Close up of switch installed at the back of the housing
Switch at the back of the housing with the LCD moved forward, connecting the power
Thats about it. Hopefully the pictures are worth 8000 words...
Alex
90 300zx twinturbo conversion
Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
The ribbon cable I used was rated high enough I think.
Haven't had any problems with any of the video inputs yet.
