It's not your res it's your refresh rate.. Go into safe mode and lower the refresh rate down to 60 and slowly move it up till it craps out again.
I started fooling around with the idea of putting a computer in my car recently.
I borrowed an lcd screen from a friend and hooked it up to a computer for testing purposes. I think it's a low-res screen because when i boot the computer, i can see the dos stuff, then the loading windows screen, but once it goes into windows i just get a white screen with grey lines.
My vid adapter only supports down to 800x600. Soes anyone know of a way to 'translate' down to lower resolution to make it work with this screen?
I lowered it to 60 and it still craps out. Any other ideas?
Were you able to see anything when you booted in safe mode?
hit up the bios - there is usually some sort of video setting there (in the EPIA bios it is CRT vs LCD). Or drag a monitor outside with long extension cord......we've all been there![]()
Use powerstrip. It can get it down to 640*480(16bit). Will work...
