Results 1 to 7 of 7
Thread: issues with lilliput
    Sep 2003
    Elgin, IL
    Armen or anyone else here,
    I'm having a wierd thing going on with my lilli 7" touch. I've found that if i power on the machine with the screen off and wait until xp fully boots then turn on the screen, the touchscreen works for a while...like 5 minutes. then it just stops functioning. if i turn on the screen immediately when i turn on the machine, it may or may not work by the time xp boots.
    even when the touchscreen is not working, xp and the touchkit.exe still detect the resistive touchscreen. it's just that if i press the screen, nothing happens. i'm thinking it may be related to a capacitor or heat or something. that time thing sort of eludes to that. any ideas would help.
    Jun 2002
    Malaysia
    If it detects the touchscreen resistive driver, the fault would lie after the touchscreen controller. It could be the wiring from your controller to the touchscreen or it could be the touchscreen itself. Seems like the +V on your touchscreen is loose
    Sep 2003
    Elgin, IL
    masch, so we're talking pull it apart and check the 4 wires on the touchscreen for resistance right ?
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Since you're not to far away from me you can ship me your usb controler and the touch panel. I will check them both and will find the problem.
    Let me know.
    Armen
    Quote Originally Posted by krystar
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Armen, my touchscreen seems not to be working too (I just bought the d**n thing from carpod.ca too). The USB controller is recognized, I can caibrate but it always registers the position at the bottom left of the screen. I have tried opening the thing up & making sure there was no pressure on the touchscreen but to no avail.
    How much would you charge to fix?
    Sep 2003
    Elgin, IL
    armen, i'm electronically competent. maybe give u a call and go some some basic checks before sending it to u and wasting both our times and frustrations?
    Sep 2003
    Elgin, IL
    armen, i just took it apart and took out the panel. from what i read, i should detect a chance in resistance on the wires if i touch it or something, right ? well i don't hehe. should i still send this to u and have u check it out? I PM'ed u my phone #. let me know. thanks armen
    armen r0000leeezz
  1. Lilliput install in and Impreza, Lilliput issues
    By SubPuter in forum LCD/Display
    Last Post: 04-19-2004, 08:56 PM
  2. Still having issues with Lilliput and Winamp Viz's
    By d1g1tal3nvy in forum LCD/Display
    Last Post: 04-19-2004, 08:48 PM
  3. Lilliput quality issues
    By fearthepenguin in forum LCD/Display
    Last Post: 03-05-2004, 11:52 AM
  4. Lilliput flickering issues
    Last Post: 01-28-2004, 09:53 AM
  5. Lilliput 7" VGA and EPIA M9000 issues...
    By heat in forum LCD/Display
    Last Post: 01-15-2004, 03:57 PM
