dont worry about the resistors, i messed up there with the same mod and thats the "common" side as to the capacitor I havent a clue but try get a solder remover tool and try clean it up as to the connector how did you break that, those connectors are so easy to unclip and reclip (grin)
good luck and by the looks of things get a lower watt iron (25watt max) and make sure it has a fine tip and you "tin" everything up beforehand
LinkBack URL
About LinkBacks
I'm the biggest fool in the world.
