Results 21 to 30 of 36
Thread: help lilliput wont power up anymore
  1. #21
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    619gl-70np
  2. #22
    May 2004
    the problem comes from the flexible flat cable (40 conductors)
    it should be changed
  3. #23
    Dec 2003
    not sure yet.
    i have two of them new. well they are kinda beat up from me messing with it. so should i attempt to try it again?
  4. #24
    May 2004
    you have 2 flexible flat cable
    one with 13 conductors
    one with 40 conductors => it is there that which interests us
    if you have a white screen : the screen does not receive any signal
    2 choices :
    -the flexible flat cable is broken
    -the connector of the the flexible flat cable is defective
    be careful with the flexible flat cable ,2 versions of lilliput
    the "old version" with the flexible cable is denudée on same extremities
    the "new version" with the flexible cable is denudée on the different ends
    have you any pictures of your lilliput ?
  5. #25
    Dec 2003
    not sure yet.
    Well here are some pics i dont know if they will help you determine any thing. How do you know if you have the old or new one?
    I meant I have two of the 40 ones. one from digi-key and the other from digitalww
    Edit: hey this is my 221 post
  6. #26
    May 2004
    can you post the picture of the connector 40 conductors ?
    with this image I can determine the version of your lilliput
  7. #27
    May 2004
    the first is the connector of old version
    the second is the connector of the new version
  8. #28
    Dec 2003
    not sure yet.
    if that is a pic of the cotroller for the screen then i think its the bottome one, with that damn little piece of plastic that comes off and is a pain to get back on....? ...although mine are not balck and white they are just all white or cream i should say.
  9. #29
    May 2004
    im not understand your last post ..
    the clasp of the connector is above or below ?
  10. #30
    Constant Bitrate ashbosh's Avatar
    Mar 2004
    Quote Originally Posted by febalone
    hey febalone,
    I have the connector in the first pic. Do you think the digitalww cable will be compatible. Here's the pic
    Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
    Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
    Holux G210
    03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  2. mobo does not support resume on power loss
    By ashbosh in forum General Hardware Discussion
    Last Post: 05-18-2004, 09:49 AM
  3. Simple Idea for keeping power to inverter while cranking....
    By syclone477 in forum Power Supplies
    Last Post: 03-23-2004, 09:03 AM
  4. Brief power loss between ACC and start
    By Destin in forum General Hardware Discussion
    Last Post: 01-26-2001, 10:12 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 09:33 AM
