Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: help lilliput wont power up anymore
  1. #31
    May 2004
    verifies that the conductors are same direction on the flexible flat cable
    and verify with the flexible flat cable of origin .
    The spacing seems correct
  2. #32
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    Quote Originally Posted by febalone
    im not understand your last post ..
    the clasp of the connector is above or below ?
    The clasp, that little plastic piece that comes off, is above... sorry
  3. #33
    May 2004
    Quote Originally Posted by jjh221
    not good .... I think that the control board or the driver card has a problem
  4. #34
    Dec 2003
    not sure yet.
    doh.... oh well i gues i have to get a new screen right? or should i try a controller board?....driver card?
  5. #35
    May 2004
    Quote Originally Posted by ashbosh
    hey febalone,
    I have the connector in the first pic. Do you think the digitalww cable will be compatible. Here's the pic
    sorry Asbosh
    but this cable do not work with your version of lilliput
    the conductors are inverse on this cable
    verifies on your original cable ,the conductors are not inverse
  6. #36
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    I have managed to loose that little white clip (bottom one), where can that be purchased at?????
    And after trying to get my screen to work without it, i think i have damaged my ribbon cable. Is the one on digitalww.com compatible with the old version (according to above)? The measument on lenght seems to be longer than mine (but the width is right), that shouldnt be a problem? Should it?
    My display was working before i took it apart to mount it, but now it's just all white.
    Also, It seems that the narrow ribbon has to be positioned to the right of the insert, there seem to be one less conductor on the ribbon then the connector, which if put in wrong, will keep the unit from coming on (no lights on the front).
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. mobo does not support resume on power loss
    By ashbosh in forum General Hardware Discussion
    Last Post: 05-18-2004, 10:49 AM
  3. Simple Idea for keeping power to inverter while cranking....
    By syclone477 in forum Power Supplies
    Last Post: 03-23-2004, 10:03 AM
  4. Brief power loss between ACC and start
    By Destin in forum General Hardware Discussion
    Last Post: 01-26-2001, 11:12 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
