those ribbon cables can be tricky. take it apart again, adjust the cables until the power comes back on, and THEN put it back together
i was trying to fit my touchscreen. and i opened the screen i only unpluged all the ribbon cable and put it back together and now i have no power to the lcd?
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
I'M DEBT FREE!!
I'm now a reasonably successful gunblogger.
i been trying for hours and the ribbon is all folded up...and i still have no power.. nothing light up cant turn it on or anything..
What do you mean no power? do you get power to the buttons? like the light on the side? does the screen light up?
i get no power at all..nothing light up..i open it to see if could fix the touchscreen problem..i just got this screen to 2days ago and now it messed up...hope i could fix it. all started with the damn touchscreen
I had same problem(I removed the cables, shorted the cap in process, won't power up). I was able to power on, but still working on the ribbon cables. The problem was the little connector called DIP2. One of the pins were bent. The ckt was open. somehow that prevented the unit from powering up. Fixed that after couple of hours of troubleshooting. I suggest you check all your connections and check whether you are getting voltages across the components etc. Good luck.
Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
Holux G210
03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
Ok first you opend it up and tried to fix it the first time and removed all the ribbons?
Now you opened up again because it does not work and nothing comes on and not lights right?
i just got it to power up...took a while to line up the ribbon..but now i get a while screen. is that mean my ribbon is messup and i need a new one?
I have no clue what you mean.
Try wigglin and jigglin it
