Results 1 to 2 of 2
Thread: using old Gateway Profile with no VGA output?
    Oct 2003
    I'd like to apologize ahead of time if this topic was discussed before. I did a search on the forum, but found nothing that helped me with my problem.
    My problem:
    I have this old Gateway Profile, and would like to use it for a carPC. I would rather make use of it then scrap a decent computer. However it DOESN'T have a VGA output. I opened it up and noticed that it is using an LVDS ribbon cable from the motherboard to the LCD.
    What i would like to do:
    Use the motherboard, but get rid of the 15" LCD and use a smaller LCD with touchscreen capabilities (lilliput or xenarc).
    What would be the best solution for this problem?
    If there is no way to use a smaller LCD screen, what online retailer sells extended LVDS ribbon cables or touchscreens?
    or should i just forget about the whole idea?
    Any help would be appreciated. Thanks.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by suprthug8d
    Throw it out and get yourself a regular computer. You can build yourself a real good computer with CPU, Memory, and motherboard w/ onboard everything for < $200. If you can even find a way to make the gateway work, it will probably need a LCD inverter board or something that will probably run you at least $100, countless hours of frustration, and never be as good as just building something from scratch. Developer (I am Chuck)
    Get StreetDeck at
    The Official StreetDeck Forums have moved, please visit us at for official support for Streetdeck.
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  2. VGA vs RCA & Touchscreen vs other
    By integsrtite in forum LCD/Display
    Last Post: 12-02-2004, 06:07 PM
  3. 800x480 on my laptop vga output
    By yourbigfun in forum LCD/Display
    Last Post: 01-07-2004, 01:03 PM
  4. VGA upgrade for TM-701L
    By digitalww in forum LCD/Display
    Last Post: 08-01-2003, 09:01 AM
