Results 1 to 7 of 7
Thread: new ribbon cable and still no signal
    May 2004
    now i dont know know whats wrong with my lilliput but damn.. this suck..i only had this screen for bout a week..i'm still gettting the white screen. i install the ribbon with both blue side up..what couldnt be wrong..if anythhing ill sell it for 200 if anyof yall know what your doing and fix it.
    Oct 2003
    DC/VA
    Check your black DIN connector it might not be plugged in all the way. Also try playing with te cables some more....they are very sensitive. Hope that helps.
    mine displays a little and it starts having red fuzziness. i ordered a new cable...dunno if that will fix the problem though.
    my gps just went out all of a sudden too...??
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    You probably have a dead controller.
    May 2004
    where can i get a new controller at?
    Jun 2002
    Malaysia
    those controllers sold alone are almost as expensive as a new lilliput.
    If you arent in US or Europe you could get a cheap new lilliput, send me a PM
    But from your problems, I suspect its the ribbon cable from the LCD to the controller. I dont know, flip your ribbon cables around and play with it. If the connection is good, then you should get a "No Signal" picture
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    Quote Originally Posted by heynicecar
    heynicecar,
    Go here http://68.77.191.217/car_computer_Version_3.htm scroll down to the lilliput install section and put your ribbon cables in this orientation. Mine was doing the same thing, but fortunately I took pictures before I took it completely apart. Hope this helps.
    Batman
