Results 1 to 10 of 14
Thread: What The Fu**.....
    May 2004
    Kent
    What The Fu**.....
    Hey check this, a while ago i posted a message saying i had problems with interference on my LCD screen well after trying everything 50 times that everyone suggested the problem still persists but yesterday i had a weird situation, i booted the PC and yet again interference on screen ,removed the cable (TV OUT) until just the core was in and the screen cleared up (not perfect) so i put the cable back in and interference again BUT as i was putting things back as i was well and truly P'd off i accidently pulled the jack plug out of the base unit which sends the sound to the RF Modulator and the signal on the screen DISSAPEARED ALTOGETHER!!!!! just went blue as if it was getting no signal and yet the tv out cable was still in, put the audio cable back in and up come the picture still with the interference!, now please anyone any idea as i now had enough and basically thinking of scrapping the PC altogether, how can an audio cable effect tv out!?!?!?!??!?!?!
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by CelicaNUT
    Ground loop?
    May 2004
    Kent
    sorry buddy GROUND LOOP meaning what? i have grounded everything in turn even run a wire directly to the battery NEG and to no avail, tried inline resistor and cap and still no help, surely its the PC somehow?!? but im realy stumped now .
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    Ground loop is when ground seeks ground thru other sources, which creates undesirable current flow. I would ground everything (all ground planes) to ground. Using no resistors. They use resistors to "pad" grounds, sometimes you get noise on ground and you use a resistor to 'somewhat' get it off of that potiential. Once you got everything grounded, start removing devices that are not needed for a display until you get a clean screen. Turn your car off, and run it off of an external 12v if nessary.
    RF is extremely acceptable to ground loops and since a car is not really at earth ground (its on rubber tires), Im suspecting that modulator.
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
    Oct 2003
    Madrid
    Yeah, I did put a question mark after it!
    It's difficult without knowing your setup but if I were in your position I'd try...
    Leave the sound unplugged and try to get the video working - the usual ways, re-install drivers, check bios etc.
    If it doen't work without the sound jack plugged in, which it should, then it's probably a faulty sys board. Did it ever work without the sound jack in?
    Edit: See, without knowing, I'm presuming it's on-board video?!?
    Constant Bitrate Needstorage's Avatar
    May 2004
    Belgium
    Quote Originally Posted by Laidback
    Could be... also check if the ground-signal of the video-cable you are using is not broken.
    May 2004
    Kent
    Thanks for the replies, i posted before basically i changed the head unit (Kenwood for Pioneer) so i can fit a CD Changer i had already, everything worked fine with the Kenwood head unit (perfect screen) but after changing the Head unit this problem appeared, i wired EVERYTHING back as it was except on the new pioneer loom but since i have had this problem so as you can imagine its annoying to say the least!. When you say ground everything do you mean a wire from the casing of say modulator/screen/headunit etc? by the way i disconnected the modulator / sound and power and the problem was still there i am running an inverter and i have noticed a buzzing from the PSU in teh base unit but i thinks it prob normal/ disconnecting the power line from the PC and having the inverter still on clears the screen (a little) sees to be picking noise up from everywhere. The screen and headunit both get power from the same wire ,inverter is powered from the cigar lighter and the amp in the boot also runs from the same wire as the head and screen. think thats it.
    Oct 2003
    Madrid
    Ok, so it's probably not a faulty sys board. You need to start isolating the components from each other while you fault find. e.g. Computer & screen on their own power & ground wires...
    Newbie shidarin's Avatar
    May 2004
    SoCal USA
    You Keep looking past the problem, it's the RF modulator. You disconnected it from the signal- so what? The antenna's still getting power. Hardwire the line without the modutor. Better sound, no interference.
    May 2004
    Kent
    So what you saying the ariel cable is picking up interference and then this is appearing on the LCD? in confused, why would this affect the signal to the screen? also i have disconnected it from the power and also from the jack plug on the base unit (PC) would this not be enough to eliminate it as the problem? should i disconnect it completely the ariel loop aswell? im only asking as its a b'tard to get to as i have a complete install in the boot and it means ripping the boot apart to get to the ariel cable sending the signal to the headunit, what are the chances of this being the cause.
