Yes, the panel will work without problem. What is happening is that the Xenarc touch panel has a slightly bigger active area then the lilliput touch panel. The size of the inside opening in the housing (lilliput) is smaller then the active area on the xenarc touch panel. When you install the touch panel into the housing it is being pressed by the frame. That is why you can move the cursor out of its current position. You need to do something like this: http://www.digitalww.com/TM-701L_VGA...touchpads1.JPG using double sided sticky tape as a spacer.
Armen
Originally Posted by badandy4you
LinkBack URL
About LinkBacks
