Results 1 to 8 of 8
Thread: Can I build my own VGA splitter
    Aug 2003
    Plymouth , MN
    Do you guys think it is possible for me to make a vga splitter so that I may be able to put a 15" LCD monitor in the roof for the rear seat passengers.
    I have one of those vga boxes but it requires power as well as being large because it was made for up to 8 monitors.
    What i want to do is get a vga extension cable and male and female plugs from my local computer store and solder the 2 males to 1 female.
    Theoretically it should be possible but I was wondering about signal loss.
    What do you guys think?
    2002 Chevrolet Avalanche
    Gigabyte Z97 mITX Intel Mobo, 8GB RAM, Intel Core i5-4590S 3.0GHz Proc, 320 GB Hard Drive, Dual 12' VGA HDMI DVI touchscreen monitors,....
    http://www.mp3car.com/show-off-your-...avalanche.html
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    If it works at all, I'd bet it produces a poor quality display.
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Sell your 8 port splitter and get a 2 port splitter. I have this one http://www.startech.com/ststore/item...r=topbarav.htm
    I was able to get it off Ebay for about $15!
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Aug 1999
    Washington D.C.
    Would something like this be of interest for around $19?
    It's just a basic splitter. No boxes or power cables.
    Connectors: HD15 Male to HD15 Female x2
    Provides performance monitor connection that maximizes color and imaging
    24k gold connectors provide maximum corrosion resistance for error-free data transfer
    Ultra-flexible jacket and oversized thumbscrews make installation easy
    Heavy-duty molded strain relief provides increased flexibility and durability
    Double-shielded foil and braid for high-resolution imaging
    Constructed of 3 individually shielded 75-ohm coax and 4 twisted pair cable to minimize cross talk, noise, and other interference
    Aluminum undermold shield assists in reducing EMI/RFI interference to meet FCC requirements
    Splits the (S)VGA signal providing simultaneous display of the same picture
    Aug 2003
    Plymouth , MN
    thats exactly what I was thinking of making . I have too many items taking up power and this will do just fine - I think
    Where can I get that?
    Aug 1999
    Washington D.C.
    Aug 2003
    Plymouth , MN
    Wow that was easy. Thanks
    MI
    I tried using just a Y-splitter VGA cable like the one above, but I noticed that as I plugged in the second monitor to it, the brightness to both monitors was cut down drastically (almost like when you switch to night mode in MediaEngine). I also started seeing scan lines in my Lilliput when using it. The splitter/amplifer did the job much better.
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  3. VGA vs RCA & Touchscreen vs other
    By integsrtite in forum LCD/Display
    Last Post: 12-02-2004, 07:07 PM
  4. vga -> composite -> vga (possible?)
    By Nav_Attack in forum LCD/Display
    Last Post: 04-03-2004, 12:38 PM
  5. VGA upgrade for TM-701L
    By digitalww in forum LCD/Display
    Last Post: 08-01-2003, 10:01 AM
