Results 1 to 5 of 5
Thread: Starvision Power Regulation?
    Aug 2003
    Does the Starvision LCD need Power Regulation for +12v in?
    I have it hooked up right now to the Cigarette lighter (I bought a $5 adapater from Radio Shack), and I don't think it does any regulation, and it seems to work just fine.
    *shrug*
    Low Bitrate Deadnick's Avatar
    May 2004
    Duvall, WA
    Until you start your car and rev the engine, Then everything goes Pooftah. I used an unregulated 12v power supply and it works liked a champ until I started the car and drove down the road about a mile then the computer would never post again because the motherboard was gone. Beware!
    Aug 2003
    Milwaukee
    sq get a regulated ps. Im using the one where you can switch the output voltage and it works great. I wouldnt connect it to the cig lighter either. It sometimes creats background noise. Use a fuse tap and connect it to the fuse box. Use the radio fuse.
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    raw car voltage can easily spike all the way to 18v and drop down to about 9V. That will kill just about anything quite quickly. Even the cheapest 5$ regulator offers decent protection as long as you don't reverse the polarity (good laptop adapters are fool proof and even if you short something it will likely protect your equipment. but those usually run off 120v).
    Aug 2003
    Well I plan to run my LCD power off my ITPS which is a +12v regulator; HOWEVER, I was told by someone on this board that the ITPS cannot keep up with supplying power to the LCD *AND* the carputer.. In this case, I need to "solder the bump" and disable the regulator.. eek.
    I might just buy another ITPS for the LCD.. *shrug*
    What really gets me is this "Egg" thing that the Lilliput comes with. Why doesn't the Starvision have one and why can't I buy one and hook it up to the Starvision??
    Thanks,
    Kevin
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  3. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
  4. Brief power loss between ACC and start
    By Destin in forum General Hardware Discussion
    Last Post: 01-26-2001, 11:12 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
