Results 1 to 3 of 3
Thread: 20x4 LCD problem
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    20x4 LCD problem
    Hi people.
    I just finished wiring up a 20x4 LCD. I've done an 8x2 LCD without problems, display worked perfectly once I got all the software/drivers working properly.
    Now, First, this 20x4 had about 15' of printer cable between it and the computer. It powered up, backlight works fine, contrast is fine. I got the two rows of squares. I set up CrystalControl to display the time. The boxes flashed off then on once a second, like it's getting the update, but just flashing to a blank display, then back to the test pattern.
    So, I read that the cable might be too long, so I cut it down to about 6', still the exact same problem. I haven't double-checked the connections yet. I'll do that after work, I'm just confused why it would flash off and on like that without displaying anything.
    I also tried using LCDPrint, but the same thing. All it does when I try to print something is blank the screen. No test pattern until I open CrystalControl again.
    Hopefully someone can point me in the right direction. I don't want to have to resolder all those connections for a third time.
    Thanks in advance,
    Kris
    Jun 2003
    Memphis - TN
    Im curious on what the Parallel mode should be set @ on a 4x20 over parallel.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Oct 2003
    Vancouver BC
    What do you mean by parallel mode? Like EPP or ECP?
    I'm going to test all the connections again on my LCD. I've Googled and nobody seems to be having the problem I've got, so it's back to the drawing board.
    Kris
  1. WinXP Problem with seeing LCD
    By EBoundEE in forum LCD/Display
    Last Post: 10-17-2003, 03:51 PM
  2. LCD problem
    By Goose in forum LCD/Display
    Last Post: 01-14-2003, 09:07 AM
  3. DVD Playback on LCD problem
    By jup in forum General Hardware Discussion
    Last Post: 02-20-2002, 08:47 AM
  4. Where can I order prewired 20X4 LCD?
    By mbowler in forum General Hardware Discussion
    Last Post: 07-22-2000, 12:06 AM
  5. Orbital 20X4 lcd power
    By titanx in forum General Hardware Discussion
    Last Post: 09-28-1999, 09:17 AM
