Results 1 to 10 of 15
Thread: Xbox 7.2 Inch LCD to VGA (like PS1 Mod)??
    Was in toys-r-us today looking for a ps1 display for cheap...$129....I passed.
    While there though...I saw 5.6 and 7.2 lcd's from Intec.
    http://www.inteclink.com/inteclink/p...reens.asp#8271
    There is a multi-AV out....and it says tft...anyone think these guys can be made to work?? Like the PS1 lcd vga mod.
    Jun 2004
    Xbox 7.2 LCD
    I bought one, took it apart and will attempt the VGA mod.
    I'll take some pictures of the unit and the circuitry. It looks like the AVinput is connected to the composite input so no luck there....
    I noticed that the screen has a controller board that receives 6 wires as input: power, ground, and other 4 (Could these 4 be R,G,B and sync?).
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    it could be power or audio too, pics would help
    Jun 2004
    Intec Xbox screen
    OK I got some pics...
    Here is what I know so far:
    • The Screen has S-video, composite and AV (24 pin) inputs
    • The AV (24 pin) and S-video seem to be connected together in the input pcb
    All of this is connected to this pcb
    Jun 2004
    Intec Xbox display 7.2 inch
    It looks like the screen works like the following:
    S-video or composite are the main inputs
    The signal is taken to a board that separates them into RGB and sync
    Jun 2004
    Intec Xbox 7.2 inch LCD
    Then the new video signal is sent to the LCD controller through a 6 pin cable
    Jun 2004
    Intec Xbox LCD 7.2
    Here are some more pics:
    Nov 2003
    Salem MA USA
    what do all of those pots do? you might be able to send the RGB signal to the second PCB and it might work you just need to do some exploring
    Try using a multimeter (if you have one) on the 6 pin connecter where the wire goes
    Jun 2004
    Intec 7.2 inch display
    The pots are for volume, bass, treble, brightness and color.
    Does this give you any ideas?
    What should I measure at the pins, I mean would I be able to measure anything on a digital signal?
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    I bought a Joytech 7.2" PS/2 screen that looked very similar to the ones listed on that site. It was STN. Picture was fairly clear, but text wasn't good. gave up on trying the VGA mod, used it as composite for a while but since then went VGA, then blew up the VGA controller, so I'm back to square one.
    4x4 in a turbo stylee.
  1. PS1 LCD working, but need NTSC timings!
    By e_fractal in forum LCD/Display
    Last Post: 11-07-2003, 12:02 AM
  2. VGA + VIDEO LCD MODULE from www.digitalww.com
    By MaleBuffy in forum LCD/Display
    Last Post: 08-09-2003, 02:53 PM
  3. Standard 10.4 inch lcd
    By Blop in forum LCD/Display
    Last Post: 07-31-2003, 01:09 AM
  4. Replies: 10
    Last Post: 06-25-2003, 07:47 PM
  5. EIO 5 inch LCD help
    By dizzzyduck in forum General Hardware Discussion
    Last Post: 03-03-2000, 08:53 PM
