According to the instruction manual included with my monitor it will support a maximum input voltage of 24 VDC. This leads me to believe there is a regulator on board already. Therefore mine is fed directly from my cars power and so far has worked flawlessly.
However on my PC I did choose to regulate the voltage but my regulator could not support both the monitor and PC. If I had a more substantial regulator I would probably have chosen to regulate them both.
On a side note my PC said it required 12 VDC in but funtioned poorly with the output voltage on my regulator set to 12. Bumping output up to 13 VDC has made my system bulletproof and rock solid.
LinkBack URL
About LinkBacks
seriously though, I have heard of lilliputs getting fried from unregulated voltage, but Xenarcs will be fine.
