My Xenarc 700TSV has been hardwired with no problems for well over a year. The input rating is fine for fluctuating automotive use. I'm sure it isn't wise to reverse the polarity (never done it), and I don't recal off-hand which wire is which. If you have the wall AC adapter, you can easily figure it out with a multimeter. Most power connectors are center-positive (i.e. the middle pin is +) and I think this is the case for the Xenarc, but better check it to be sure!
The car 'adaptor' must be a big waste of money, as all it will be is a cigarette lighter plug and some wire. Unless you want to easily unplug your screen, hardwiring is fine (you can use any plug for that matter, wired in to the car's power).
LinkBack URL
About LinkBacks
it appears some people have burned their screens out using the car adaptor because they reversed the polarity. From what I read some people took the wire with the lettering as the positive...
