Results 11 to 20 of 30
Thread: Inspiron 2500 LCD
  1. #11
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    Quote Originally Posted by Yuriy
    3. Your ribbon only has 9 wires in it - I had 45 in mine.
    I wonder if that's going to be the difference. Two different types of signals right? Can they both be extended to the same length?
    I don't have any idea, I just thought I'd throw that out there.
  2. #12
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    Pretty impressive but no photos of the actual extension. That would be interesting to see... with 45 wires.
    Welcome, cdm.
    You last visited: 09-13-2006 at 02:42 AM
    Private Messages: Unread 0, Total 3.
    Wow.. how things have changed in 4 years. Gone are the days of mcgyver and datalux
  3. #13
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    Quote Originally Posted by cdm
    You just won't give up, will you?
    Okay, you made me get up and take a picture of my LCD's back side:
    Here you can see the extension cables before I hid them this morning:
    And this is how the damn thing looks before extension:
    I'm sorry, I lied about the 45 wires. There were actually 42 for the LCD cable and 5 more for the inverter cable, which makes it 47
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
  4. #14
    Jun 2004
    Seattle
    Quote Originally Posted by eCar™
    Correct.
    You can extend the LCD signal for as long as you want, but the backlight signal has to be done this way:
    The way it works is the computer sends a signal to the inverter board, which then amplifies it and sends to a gas lamp which is the actuall backlight. The key is to keep the INVERTER<>BACKLIGHT cable as short as possible and then you can extend the COMPUTER<>INVERTER cables. Apparently the signal from the inverter gets weaker as the cable gets longer, but the signal from the computer to the inverter can be extended.
  5. #15
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    nope
    But I was curious. Actually i might now try to do that with an old laptop of mine.
    Welcome, cdm.
  6. #16
    Low Bitrate Aksor's Avatar
    Mar 2004
    Ottawa, ON
    I did a few myself and it all depends on the type of lcd Interface used on the laptop.
    If the interface between the motherboard and lcd is LVDS then you should be able to extend it to a few meters. if it's individual color bits and sysnc signals then the max you will get without visible jitter is ~18". Any longer than that and your display will roll and tear and display weird anomalys.
    This is due to the high data rates. I actually connected a laptop screen to a PCI controller card using a 2' shielded cable with separate cables for clock and colour signals. The display was working but I could still see interference on the screen.
    Laz
  7. #17
    Jun 2004
    Seattle
    Quote Originally Posted by Aksor
    Laz
    Well, now that you mentioned it - I do see some minor interference on mine..
  8. #18
    Jun 2004
    On Another note, I just took apart another laptop, its a old Toshiba Tecra 8000, the LCD is quite different then the Inspiron 2500, is there anyway to intergrate this into the Inspiron and do away with the Inspiron LCD? What would I need to do this? I'll attach pictures. Sorry for all the questions, Im still new to this and thanks for all the help.
  9. #19
    Jun 2004
    Seattle
    You won't be able to connect this to a different laptop, but extending it will be a breeze.
    Why not use a Toshiba instead of Dell then?
  10. #20
    Low Bitrate NorthGaVigor's Avatar
    Tenneessee
    You guys seem like the experts i need! I have acquired a Hitachi 14.1" touchscreen. (TX36D75VC1CAB) It appears to have a ribbon cable, a two wire connector (power i assume) and then a spot for another ribbon cable on what i believe is the touchscreen controller. I would love to get this thing to work if anyone has any ideas on where i could get some info involving pinouts and such. It came in a Cimlink Delta Airlines Diagnostic tablet minus all of the guts of the tablet.
    www.natchezss.com
    God Bless America and Our President!
  1. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  2. Lilliput LCD monitors
    By 001 in forum LCD/Display
    Last Post: 10-27-2003, 03:46 PM
  3. Replies: 0
    Last Post: 05-18-2003, 11:59 PM
  4. lcd datasheet help
    By oddcomp in forum LCD/Display
    Last Post: 11-08-2002, 11:24 AM
  5. Replies: 5
    Last Post: 08-20-2002, 09:32 PM
