Results 1 to 8 of 8
Thread: RE: New Lilliput - Ribbon Cable Problems
    Low Bitrate 047025n's Avatar
    Feb 2004
    Halifax
    About 3 weeks ago I opened up my lilliput touchscreen to make and in dash fiberglass mold. The mold is all done but when I put it back together the monitor would turn on, but it would not display a picture. I played with the cable a bit and the picture would come on, but the slightest movement and it would disappear again. After some reading I decided to give a new ribbon cable a try to get a better connection. However, after purchasing this cable from digitalww and plugging in the new cable I can not even get the picture to flash on the screen even intermittently. The touchscreen is working
    fine and the screen turns on, but it is white. As well the blue side of the cable is up at both connections.
    If anyone can give me some suggestions that would be fantastic, because im about ready to buy a new screen if i can't figure this out.
    Jun 2002
    Malaysia
    if it turns on and doesnt say "NO SIGNAL" then the problem is with the ribbon connection between the VGA connector and the LCD panel.
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    Quote Originally Posted by 047025n
    047025n,
    Go to my webpage www.samshomepage.net look at the setup for version 3, there are pictures showing the direction of the ribbon cables. Pictures aren't the clearest, but you can see the orientation of the cables.
    Batman
    Batman@TheNewBatcave.com
    AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
    www.Cars-N-Computers.com
    Feb 2004
    Halifax
    Bump .. Im still unable to get this working with the new cable... Armen do you have any suggestions?
    Constant Bitrate ashbosh's Avatar
    Mar 2004
    I'm in the same boat. White screen, changed ribbon cable etc but no luck. Totally frustrated by cheap a$$ Lilliput. . Motorcity offered to take a look at it and try to fix if possible. Still waiting after 2 weeks... You can try him if you want.
    Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
    Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
    Holux G210
    03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
    May 2004
    Hey where did you get the ribbon cable from? I am in the same boat as well, the ribbon cable is Fu&*(&D and i need a new one. Thanks.
    Sep 2003
    Newark, Ohio
    Look at this picture. Larger one can be found on my site. One side of ribbon cable (blue) is up, other side is down.
    Batman
    Oct 2003
    DC/VA
    I ordered my replacement ribbon cables from digitalww. Armen got them to me in very good time.
  1. need lilliput ribbon cable
    By cybermob2 in forum LCD/Display
    Last Post: 05-21-2004, 10:17 AM
  2. WTB ribbon cable for Lilliput
    By nthai in forum Classified Archive
    Last Post: 05-16-2004, 09:48 PM
  3. Lilliput problems (yet some more)
    By samc in forum LCD/Display
    Last Post: 05-06-2004, 10:51 AM
  4. Extend lilliput ribbon connector?
    By nick9871 in forum LCD/Display
    Last Post: 04-08-2004, 09:05 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
