I am having the same problem. I get an image but its split in two, the image is not streched enough.
Hi,
I'm new here and I have already learnt a lot from you guys. I just got myself an old Matrox Millenium II 4MB PCI, but I can't het it to work. I followed starfox advices, some other guides I found on the Web, but no way. Before that, I succeeded with a Radeon 9600 Pro, with the Powerstrip timings as recommended in a guide by Serio, but now with the matrox, I cannot get anything correctly synchronized. First, the pixel clock will not go below 30Hz, everytime I try to set it to a value below (the usual 15 I used with the radeon), it just jumps back to 30.xxx.
Then, after a few changes in Horizontal and vertical sync values, it all hangs and I must reboot the computer.
please can someone help me and provide me valid Powerstrip settings for the MilleniumII and a psone lcd screen ?
Thanks a lot !
PierreLo
By using VNC or other program to remote control carPC and post a print screen of Powerstrip setting (like I did in other thread) so that some of us maybe able to help you guy out. Images such as VGA->LCD solder point or the modding part will also help. Sometime you just miss a solder point and didn't realize that. I had that problem and thanks to my bro he pointed it out base on the circuit and drawing laying on the floor.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
the M II CAN'T go below 30hz Unless you HACK the M II Bios. There's a post about it a bit back here's the post
Matrox video card with PSone Screen
I could not get this to work on MY MII I bought a Geforce 5 instead. I also made a Driver for the PSONE to try to get the hz down it was somewhat seccessful.
Mage
Hey Mage, could you get me a copy of that driver? Also, you said you were "somewhat successful", what went wrong?
I'll have to remake the driver I formated the drive so I can post it when I can for you guys. uhm as far as "somewhat successful" I got it to Work save that the pixel clock was at 30hz and if would flip slowly I belive here's my post about what I did and everything that happend (it got off track somewhat though)
Help with PSONE LCD mod
Mage
THanks a lot to you guys for your answers (both here and in PM).
In the meantime, I gave up on this matrox and I'm trying to get me an old PCI radeon card, since it seems it works fine on my Radeon 9600 Pro so I guess my best bet is another radeon card.
I also have tried with a S3 virge, but couldn't succeed (csync is not supported on this board by the way).
PierreLo
all the s3's (trio64,steath,2000,3d) dont work. also any ATI card before the radeon's dont (the mach64 based ones) and I could not get a Geforce 1 nor an otherone (for get the name) to work.
any radion should work but I think the best is a TNT 2 pci I belive.
Mage
I tried a 32Mb TNT Vanta and it worked great. I just put the settings for Arcade and the image was almost perfect. Just have to put the 270ohm resistors to make the image brighter, but other than that its perfect. My only concern now is that it actually gets quite hot, which means it takes quite a bit of power. I'll have to test it out with my ITPS to make sure it can handle. I used my 52x cdrom the other day and teh ITPS couldn't quite handle it and the computer was restarting when it tried to read the cd.
Quite interesting. I never thought about TNT. Maybe I'll try to get one on ebay. Thanks for the tip.
PierreLo
