Results 1 to 6 of 6
Thread: rotate Lilliput display 180 degrees
    Jun 2004
    I would like to be able to rotate the Lilliput LCD display if possible. I have the MIA1000 board. This has to be able to switch back and forth 180 degrees, so I was looking for a utility to do this. Any free ones?
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    pivot pro. works great even at 90 degrees.
    (gives native 768*1024 resolution, kinda cool)
    -Mars
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Given that the rotation is being done is software how is movie playback on a rotated screen? Is it viable to flip the display, bold a laptop to the roof and watch DVD's on it (with the screen rotated 180 degrees) ?
    Chris.
    Nov 2003
    Massachusetts
    I just tried the eval of Pivot Pro and made a real mess of my laptop. It appears to install an out of date and unsupported video driver, I got stuck in a very weird resolution, mouse wouldn't work, couldn't uninstall it, couldn't see all of the screen. Fortunatley I managed to get to the XP Restore Point screen via the keyboard and got out of the mess.
    Software looks promising, I'm willing to believe my issues were due to special drivers for my laptop screen (1600x1280 Toshiba) but be careful. XP doesn't make a restore point automatically so make one yourself before installing.
    Chris.
    Feb 2004
    Montreal
    I had no problem when I installed, it does fool with video drivers, that is why it is transparent to the OS when it works.
    Since it is a modified video driver, video playback is seamless (for me at lease) but if you go 90 degrees on a full screen, the 16:9 becomes 9:16 and doesn't look all that good... some software will have massive unused space as it keep aspect ratio, which might be better, but the image is quite small.
    hope that helps.
    -Mars
    Jan 2004
    If you are using a Nvidia video card there is a setting under control panel that will rotate your desktop 90º, 180º, or 270º. I know because my lilliput is mounted upside down in my car.
  1. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
  2. Display area of Lilliput 7in
    By bobbykokinos in forum LCD/Display
    Last Post: 03-17-2004, 09:49 AM
  3. WIERD Display on Lilliput...HELP!
    By Norrin302 in forum LCD/Display
    Last Post: 03-09-2004, 09:48 PM
  4. Small Lilliput display problem
    By Da_Teach in forum LCD/Display
    Last Post: 03-01-2004, 07:23 PM
  5. Possible to flip VGA signal 180 degrees??
    By Glyn in forum LCD/Display
    Last Post: 01-07-2004, 12:07 AM
