Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Why won't my Xenarc 730tsv display 800x480/848x480
    Feb 2004
    Why won't my Xenarc 700TSV display 800x480/848x480
    For some reason, whenever I change the display to either 800x480 or 848x480 at 60hz in power strip, my Xenarc picks up 640x480 and looks like crap. However, 800x600 at 60hz works fine. Any ideas?
    Feb 2004
    Anyone?
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by Mears
    Anyone?
    I have this same problem. There is a FAQ that says you can fix it by using powerstrip to change the refresh rate in small increments like .1% until it picks up the correct resolution, however, I have been unable to get this to work either so I just run it in 800x600.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Feb 2004
    No kidding. So is this a defect in some units or does it apply to all Xenarcs? 800x600 is way to disproportioned for my tastes.
    Oct 2003
    some step more then me... i CAN'T change the resolution in powerstrip, the button "customer resolution" is disabled, someone know why?
    Mar 2004
    WHat Motherboard you got / grpahics card?
    If its the M10000 epia hen thats y. it dont support custom resolutions
    have to wait until they bring us a driver
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Unfortunately I can only get 852x480 (beside the standard resolutions)...
    Banned eatyummypuppies's Avatar
    Feb 2004
    li, ny
    Many applications don't fit on the screen at 800x480. It's really not worth using unless you're watching movies. But you could probably solve that problem by setting up ffdshow to decode and compensate for the screen's ratio.
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    Technically 853x480 is the perfect resolution for viewing 16:9 movies. 848x480 is the darn close. 800x480... I'm not sure what that's used for.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    800x480 is the native resolution of the Lilliput/Xenarc LCD panels.
    If you've ever seen a desktop LCD, you will know that it is MUCH crisper at it's native resolution than at a non-native resolution, as when it's in it's native resolution, you are mapping pixels 1:1, but when it's non-native, you may be trying to display 1 pixel of the signal in 1.3 pixels on the display, which it can't, so it "blurs" them together, making the picture less clear.
    Therefore, the perfect resolution to run on the Lilliput/Xenarc is 800x480, to get that 1:1 pixel mapping
    The screens are actually 15:9, not 16:9, like "Widescreen" TVs etc are.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  1. What size barrel plugs for Xenarc 730tsv and Audigy NX 2?
    By Mears in forum General Hardware Discussion
    Last Post: 08-29-2005, 06:26 PM
  2. Replies: 5
    Last Post: 08-17-2003, 07:15 PM
  3. Xenarc display improved
    By jermaine in forum LCD/Display
    Last Post: 03-26-2003, 01:45 AM
  4. Xenarc and Via M (display issues)
    By aggie300zx in forum LCD/Display
    Last Post: 03-21-2003, 11:36 AM
  5. In Dash Kit for 7" WS display Xenarc
    By gunnt in forum LCD/Display
    Last Post: 08-22-2002, 03:53 PM
