Results 1 to 10 of 12
Thread: Fried my Lilly ?
    Sweden
    Unhappy Fried my Lilly ?
    Wow, that was fast - got my Lilliput 7-inch touchscreen today, and used an AC/DC Adapter as described here ( AC-DC Adaptor fit Lilliput ? ) to power it.
    Worked fine for half an hour or so, and then it just went black. No drama, no smoke, no nothing - just shut off. Now I cant get it to work again.
    Any ideas as to where I should begin debugging the screen?
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    did you try plugging it in to the AC power adapter that it came with to determineif it was the screen or not.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Try another adapter. You need one that can supply ~800mA or more at 12V. You can go as high as 12.6V to get a slightly brighter screen but I wouldn't risk going higher. If your regulator was using a higher voltate, you may have blow your Lilliput. If you regulator was rated at under 800mA, you may have blown your regulator.
    Either way, the easiest thing to do is test it with the OEM AC adapter.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    My egg regulates @ ~12.8. The screen is kind of wavy, thought it was dirty power. Too much? Should I hook up to my ITPS/PW-70?
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Sweden
    Thanks for the replies,
    Im getting an adapter for the wallsocket first thing tomorrow (its an american wallsocket type thats delivered with the lilli, right?) and try it out.
    Quote Originally Posted by rando
    The adapter outputs 12 V, and 500mA. But I dont understand how I can fry something (the regulator) by giving it too LITTLE current?
    Where is the regulator, and is there any way to fix it?
    Jun 2002
    Malaysia
    try the two adapters that came with the lilliput
    first the AC adapter
    secondly the car adapter (egg)
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by Danneman
    regulator = wallsocket adapter = dc-dc psu = whatever you were using. If it isn't designed with overload protection, you can fry it by hooking up a device that trys to pull more current than it can supply. The Lilliput needs ~800mA. The 500mA adapter you are ordering is underrated for the job. It may or may not power your screen and then may or may not survive. Order the correct adapter.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Right,basically what rando's saying is that it's not fried, but may not work because it is simply not recieving enough current.
    2 Kicker Comp 10"
    Check it out?!
    Mar 2004
    Redondo Beach, CA
    Right ... maybe. Your LCD may or may not be fine. I don't see how anything in the scenario you described could have damaged your Lilliput. It IS possible that you damaged the regulator you were using to power the Lilliupt. It's also possible that if you are using an underpowered regulator that it simply won't work or may work only intermittently.
    The only way to to test your LCD is to get a good power source (i.e. a regulator that matches or betters the requirements of the Lilliput; 800mA @ 12V). For instance, you could use a +12v output from an AT or ATX power
    supply to test it.
    Sweden
    Thanks for the explanation - makes perfect sense now. Come to think of it, the regulator WAS very hot when it was feeding the lilliput, whereas the lilliput wasnt.
    Alright, Im off getting an american-to-swedish walladapter. Thanks again for the help
  1. Fried Inverter due to reversing polarity???
    By wonderworm in forum Power Supplies
    Last Post: 03-24-2004, 01:46 PM
  2. Wanna power this laptop since I fried my system today.
    By MikeHunt79 in forum Power Supplies
    Last Post: 07-07-2003, 12:24 PM
  3. Rats, I fried my keyboard port.
    By waltsongs in forum General Hardware Discussion
    Last Post: 04-04-2002, 08:24 AM
  4. I think I fried the lcd controller on my pcm-5862
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 03-05-2002, 04:07 PM
  5. Telling if you've fried your display????
    By MP3IAN by Ian Gregory in forum LCD/Display
    Last Post: 02-07-2002, 05:40 PM
