who has an 8" in stock?
fitting them into a double din might be tough...you'd have to see if they were any wider than the 7"s...nevermind the height. you could probably do it without the housing
Has anyone installed an 8" lilliput in a double din? got pics?
I tried searching to no prevail. They seemed to be dropping in price.
Thanks.
MJH
rebuilding carpc... kinda..
http://cgi.ebay.com/ws/eBayISAPI.dll...100860000&rd=1
Here's one from electronicar
well thats about 8x6.5"...im assuming with the housing. measure the opening and see how much its off by
way too big for a double din. There's a double din concealed behind this...
Remember, it's a 4x3, and the 16x9 7" are a tiney bit larger than the double din.
car computer rev 5: 8" lilliput and usual suspects
thank for the quick replies...i'll stick to getting a 7"
where there's a will, there's a way! the lillput 8" is an exceptional screen, just need to find somewhere to stick it...Originally Posted by mykolJay
does anyone know the size of a double din off hand...unfortunately, I don't have my car nearby. I live in NYC.
From looking at a Mazda thread, they said doubledin was about 7.5 x 4.2 x 7.
Can that be confirmed?
I wish I could see an example, I'd rather not cut the dash too much. or have to extend the buttons.
you don't have much of a choice in the matter. the 7" lilliput bezel, plain and simple, is larger than a double din...Originally Posted by mykolJay
I have a 7" Lilli in my double din openeing. I can tell you that the panel itself (bezel removed) is slightly larger than the opening. The viewable area of the panel is just a bit smaller than the opening. What I did was trim the bezel down to be the same size as the panel itself and then flush mounted it from behind. There is no way an 8" is going to fit into a standard double din.
