Results 1 to 10 of 10
Thread: Notebook Car-Adapter Noise on LCD
    May 2004
    Hi !
    I use my notebook as a carputer.
    I use a 12v to 20v converter to power my notebook.
    But everytime I plug in that converter, my lilliput screen starts to flicker.
    (slow moving horizontal lines)
    I tried grounding both my lilliput and the notebook converter to different places in my car. didn't help.
    Also strange is the fact that I can remove the ground of my lilliput and, as long as the VGA-cable is connected, it will keep working. VGA cable is acting as a ground for the lilliput?
    When I remove the 12-20v converter (notebook running on battery), the screen is perfectly stable.
    Anybody knows a solution to this ??
    thanks in advance
    Apr 2002
    Sweden
    I have the same horizontal lines on my lilliput when I run it with the ac-dc adapter and my notebook with ac-dc adapter.
    Haven't test it in my car yet.
    Dec 2007
    I'm getting the same type of noise on my lilliput... I'm using a dc-dc 12v to 18v psu...and a laptop.
    what's the best thing to do to try to solve this??
    thanks!
    Feb 2008
    I have same problem too.I use indash lilliput and carpc with m3-atx.I don't have solution to do with this problem too. Who will help me?
    May 2008
    I am have the same problem and more here is my post http://www.mp3car.com/vbulletin/lcd-...-problems.html
    I have purchased a loopback filter for the power running into my car. I am going to put one on my 7000 and one on the power coming into the car. I hope this works. It worked in my circuits class! So I am guessing it will work here. The only problem is that the filter that I got is only rated for 100 W. So we will see. I will let you guys know after I get it installed.
    Sep 2008
    Hi,
    Was any solution found to this problem?
    I have the same problem, using a Sony Vaio laptop (19v) and a Lilliput screen all is fine when running on the laptop battery, nice clean screen then when I needed to plug the adaptor into the laptop to power it I get lines all over the screen.
    When cruising on the motorway at 3,000rpm the screen is clear so I assumed the adaptor was struggling so bought a Carnetix P1900, just finished wiring that in today and once again I am getting the lines on my screen when the carnetix is powering the laptop.
    I also have just noticed that if I put any load on the alternator (turn on heater fans etc) the lines get worse.
    I am using my Carnetix to power the laptop and my usb hub and a seperate 12v ingition feed to power my Lilliput.
    My car is an ex-police Volvo with a 100amp alternator so it is not even a puny alternator that is struggling.
    So basically picture is fine on the screen turn on laptop and run it on battery and all is nice and clear, as soon as the laptop has the external power plugged in the lines are there straight away but go away if I unplug the power and run off the battery.
    Any suggestions would be gratefully received.
    Dec 2007
    hey guys,
    the only solution I found to this problem was to get another dc/dc adapter... this time I got one made exclusively for my hp/compaq laptop, with the right voltage and amperage (18.5v 3.5a), instead of one of those universal type ones...
    after that installed, the lines were almost completely gone!
    Sep 2008
    Hi,
    After switching to the Carnetix 1900 from my universal adaptor the lines are slightly lessened but still there, but only when on external power, all is clear on battery.
    They aren't bad enough to really worry about but enough to annoy a fussy bugger like me ;-)
    Paul.
    Newbie m0r473n53's Avatar
    Mar 2009
    I have same problem too. somebody can help me?
    MAZDA MX-3 1994
    Nov 2009
    Canada
    Same problem here.
    I am using the P2140 and I get a lot of flickering and lines. is this a voltage issue?
    Can I increase the secondary 12V output on the P2140?
    I think my touchscreen came with a power filter which I'm not using because it has a cigarette adapter on one side. Maybe I should chop this up and put it between my P2140 and my touchscreen
    any ideas? this seems to be commonplace
  1. Laptop in car (no LCD)
    By 93AltimaSE in forum General Hardware Discussion
    Last Post: 01-23-2004, 11:36 AM
  2. How do you fix alternator noise on an LCD?
    By adamis in forum General Hardware Discussion
    Last Post: 08-23-2003, 09:31 PM
  3. Has anyone tried a usb printer adapter for a parallel LCD?
    By ShinkunoNamida in forum LCD/Display
    Last Post: 02-21-2003, 04:48 AM
  4. Chinese car LCD and relative products supplier!!!
    By iamchen in forum Classified Archive
    Last Post: 11-28-2002, 09:34 AM
  5. playstation in car with an mp3 adapter
    By johnnystorm in forum General Hardware Discussion
    Last Post: 05-06-2000, 04:56 AM
