Hello
I bought LCD panel and the controller of the TM 702s.
How to connect the pinout,or is the video1, video2, power............?
Thank you
Button pinouts
From Left to Right
Pin 1 - Power
Pin 2 - Menu
Pin 3 - Menu -
Pin 4 - Menu +
Pin 5 - V1/V2
Pin 6 - IR
Pin 7 - IR
Pin 8 - Ground
Power plug pinouts
From Down Up
Pin 1 - +12V
Pin 2 - Ground/Ground for V1/V2
Pin 3 - V1
Pin 4 - V2
Armen
Originally Posted by mipec
Thank you Armen,but for
Where is pine 1, has right or has left?Originally Posted by digitalww
There are 5 pinOriginally Posted by digitalww
And for the problem with my DWW-7VGA?
For the button board pin 1 is the most LEFT one.
For the power connector pin 1 is on the bottom. You only need 4 pins. The top pin is unused.
What is the problem you are having with your DWW-7VGA?
Armen
