Lilliput 4-point and 25-point calibration?
the touchscreen works great, but i can't get to the "x"'s at the upper right corner of the window (in Windows) to close a program, or even to hit the Start button on lower left corner, or anything minimized in the task bar. the touchscreen just doesn't see these areas. i think that i need to use the calibration tool that came with the drivers.
when i run the calibration tool (4-point for example), it shows a little blinking "x" in the lower left corner. you are supposed to touch the X when it stops blinking. but the time that it takes between stopping blinking and failing the calibration is like half a second or less! i can't press the X fast enough for it to register. i automatically fail the calibration. is there any way to do this?
