You're supposed to press and hold the X, then when it beeps, press the next one.
the touchscreen works great, but i can't get to the "x"'s at the upper right corner of the window (in Windows) to close a program, or even to hit the Start button on lower left corner, or anything minimized in the task bar. the touchscreen just doesn't see these areas. i think that i need to use the calibration tool that came with the drivers.
when i run the calibration tool (4-point for example), it shows a little blinking "x" in the lower left corner. you are supposed to touch the X when it stops blinking. but the time that it takes between stopping blinking and failing the calibration is like half a second or less! i can't press the X fast enough for it to register. i automatically fail the calibration. is there any way to do this?
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
ha! the wording on the screen isn't worded very well, so i wasn't sure. that makes alot more sense... i'll try it.Originally Posted by Pudge
thanks!
Yea, took me a few times to get it, it says touch, i thought i was just supposed to keep tapping.
2 Kicker Comp 10"
Check it out?!
