Results 1 to 10 of 12
Thread: Lilliput help please...
    Mar 2004
    Denmark
    Hello to you all....
    i have a small problem with my lilliput, it is totally impossible to get the screeen to react on the middel of the right side...when i press the screen there, i canīt seem to get to the very border of the screen.....so its impossible to scroll down cant reach the side.....
    and another thing, : my carīs battery died out yesterday, and and after i re chargeded it, the screen seems to have been darker, contrast....is lower.. ( hope you understand what i meen, im from denmark so English in writing isent very good.)
    Anyone has an answer to this ????
    BR
    Kenneth
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    I have a problem with my Toshiba e740 Pocket PC where I cannot access bottom and top right corners of the screen and calibration does not help. This is due to a damaged touchscreen. Even though you might not see any cracks on your screen, there could still be something wrong. If your lilly is under warranty, I suggest you either fix it or exchange for a new one. To make sure it's really broken, try hooking it up to a different computer.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Mar 2004
    Denmark
    it is a bit of a problem for me, cause the screeen is bulit in to the dashboard and is very hard to remove....
    it is only 3 months old, so still warrenty on it....couldnīt it be a problem with the drivers......
    BR Kenneth
    Jun 2004
    Seattle
    It is possible that your monitor got a micro-crack somewhere when your car hit a bump.
    I just know that touchscreens can have certain areas disabled permanently.
    It could be just a calibration problem though - have you tried re-calibrating the touchscreen?
    Sometimes when you use your finger a lot the calibration gets a little messed up, especially on Pocket PC's. I'm pretty sure that the lilliput screen has the same property.
    A driver problem is very unlikely. This looks like a typical case of "out of calibration".
    That is unless you have already tried recalibrating it.
    Mar 2004
    Denmark
    i have tried to recalibrate it, more than ones...the only thing i havent tried is un installing the drivers and installing them again....mayby it couldt help?????????
    the screen worked fine when i first got it... and i canīt remember to have ever hit a bump......
    Oct 2003
    Calibration
    Did you do the BIG CALIBRATION? the 24 Point one? Do THAT calibration, not t he basic 8 one (or whatever low number it is).
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    4, and remember "press and hold"
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Jun 2004
    Seattle
    And of course if that doesn't work - reinstall the drivers. After that you can be sure whether it's broken or just buggy. Remember - the calibration settings are stored in the registry, and damaging the registry (even on a Pocket PC) can cause the calibration to go out of control. Damaging the registry is easy - you just have unplug power from your PC without shutting down properly. Even if a small area of your touchscreen has gone bad, you can still tweak the registry to compensate for it. It's a hard task though, especially if you got some 24 calibration points..
    Low Bitrate savante's Avatar
    Jul 2004
    Chicago
    Have you had any solution to this? I just purchased a Lilliput screen off ebay and received it yesterday. I have the exact same problem with the right side of the screen. I can reach both top and bottom corners but not the middle of the screen.
    Is this just a bad LCD?
    Jun 2004
    I too have this issue and have not been able to resolve. During the 25 point calibration (done MULTIPLE times) you can see the last 1/2" or so of the middle right is off.
    No changes were made to the system at the time the problem started happening. no new hardware/software/drivers.
    It is a constant problem, not intermitant.
  1. WTB: BROKEN Lilliput 619!
    By masch in forum Classified Archive
    Last Post: 12-14-2004, 04:58 AM
  2. Replies: 2
    Last Post: 06-20-2004, 12:10 AM
  3. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 01:54 PM
  4. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 07:58 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
