Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Lilliput TOUCH SCREEN StOpS !!!!!!!!
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Question Lilliput TOUCH SCREEN StOpS !!!!!!!!
    HI brought a 7" lilliput touch screen. and have not opened any casing...
    working with XP and the drivers and the associated software is properly installed.
    AND now comes the problem. After working with the TOUCH SCREEN for a FEw mts ( 10 or so ) the TOUCH screen DOES not RESPOND.
    Have tried to reclibrate 4 point and 25 point option. and again the same PROBLEm Stops working after 5 to 10 mts.. but the problem is solved once I reboot the system ( Works againg for a few mts before it stops responding )
    had a look at the cables and well could not see the RIbon so...
    CAN SOME ONE PLS HEEEEEEEEEEEEEEEEEEEEEELP !!!!!!!!!!!!!!111
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Dude....relax
    You have to open up the case to see the ribbon cable. You might want to just send it back
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    My first guess is that his computer is freezing up and it has nothing to do with his touchscreen at all. I get those calls all day at work. "My mouse isn't working!!!!" Then after the reboot, the computer has fresh resources and all is good. I want to know how much memory he has installed, what apps are running at the time of the error, go into task manager and tell us what you CPU Usage is at.
    ATVMS.com
    Dec 2003
    AM working on P3 512 MB ram.
    the system is working finee with the mouse EVEN when the TOUCH SCREEN stops responding . WEll this happens with all applicatins.
    MEDIA ENGINE and for that matter even if its JUST WINDOWS on the main screen with out any other application running.
    and CPU useage is 54% ONLY
    Just opened up the casing and I see no RIBON damage. ( and IF thre was a damage of RIBON wire ;; the touch screen would not work at all ) but in my case its working for a few mts before it stops
    HELP PLSSSSSSSSSS
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    what other software do you have running that use com port/s resources ?
    Bluetooth software is notoriously problematic with liliput touchscreens
    and cpu usage at 54% is high
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    FS = MTSVO motorised in dash screen pm me for details
    Mar 2004
    bluetooth is notorious problamatic?
    ummm oh dear!
    is this just certain brands of bluetooth devices, can imagine it being all....
    J
    Dec 2003
    wELL JUST USING phone control AND dlink usb BLUETOOTH.
    Feb 2004
    ok let me correct myself, maybe its not the bluetooth software as such but the driver stack behind it that seems to create a touchscreen issue, normally a simple uninstall of the bluetooth software, install touchscreen and then calibrate touchscreen as per the instructions on the cd / file that came with the touchscreen, then once thats working reinstall the bluetooth software / drivers and all seems 100%
    Dec 2003
    ok let me try that . by uninstalling the blue tooth software.
    but its kind of good to use phone control as well ..
    Feb 2004
    uninstall the bluetooth install the touchscreen, get that working and then reinstall the phonecontrol software
  1. Lilliput screen flash
    By lgbr in forum LCD/Display
    Last Post: 12-13-2005, 12:15 PM
  2. Help with Lilliput 7" Touch Screen
    By webnosis in forum LCD/Display
    Last Post: 03-24-2004, 12:46 PM
  3. GROUP BUY: Lilliput TM-701VGT LCD
    By krystar in forum Classified Archive
    Last Post: 01-16-2004, 07:31 PM
  4. Replies: 4
    Last Post: 10-25-2003, 05:29 AM
  5. Anyone know about Lilliput 7" XGA Touch Screen
    By koyoutou in forum LCD/Display
    Last Post: 10-06-2003, 12:37 AM
