Is the screen in the original housing? Does the cursor jump to a corner or the edge? If this is the case, I have the same problem. Its because the case is pushing on the screen. I have the same problem, and its only due to a sloppy install into the DigitalWW fold out dash unit.
If its not jumping to a corner, but instead jumping all over the place, are you using a serial GPS unit? If so, unplug it, and if the jumping stops, you have to go into your Device Manager and disable the Serial Mouse that Windows autodetected. Just disable it, don't uninstall it. Plug back in your GPS, and you should be in good shape.
If these don't fix it, hit it really hard with a big hammer, and you won't have to worry about your cursor jumping around anymore....![]()
LinkBack URL
About LinkBacks
