Results 1 to 6 of 6
Thread: New Problem with Lilliput Screen!
    Dec 2003
    I have sucessfully used my lilliput in my car setup since November and worked perfectly and now since it has gotten hot in boston my lillput does not respond very well to touch....I have to push hard and sometimes it does not even register....I rechecked all the connections and they look good and I also unplugged other USB devices still no luck. The computer seems to run fine, it just seems the touch screen is not working! Does temperature / humidity affect the lilliput's touch response, or am I overlooking something. Thanks in advance.
    May 2004
    phoenix
    i'm in arizona and my lilliput doesn't miss a beat in 113°F+, but i wouln'd know about humidity...
    Dec 2003
    Today after a heavy rain the screen works fine........therefore I think the effectiveness of the touch screen is directly related maybe to humidity and not so much temperature.....I guess it works based on resistance and maybe the humidity screws up the sensor.
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    Quote Originally Posted by drmaximus
    that makes no sense, after heavy rain the humidity would be high. resitance is more likely to change according to temperature rather than humidity. But i doubt its either.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Dec 2003
    Quote Originally Posted by no1knows
    nah, right after a heavy rain all the water has unloaded from the air....so the humidity drops.....the temperature drops also, but if ppl are using it in phoenix at 113 degrees than i doubt its the temp.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    It is the heat.May people have experienced this and posted on theis board...
    Your touchpannel is becoming unglued from the LCD due to heat. Take a close look at it. Does it appear to be comming off?
    You may need to order another touch panel and replace it. DigitalWW has direct replacements for a decent price.
  1. Lilliput TOUCH SCREEN StOpS !!!!!!!!
    By vicky_obee in forum LCD/Display
    Last Post: 01-07-2007, 07:37 PM
  2. Lilliput - linux supports usb touch screen?
    By chenko in forum LCD/Display
    Last Post: 10-03-2004, 06:58 PM
  3. Should the Lilliput screen be a little loose?
    By the_dude in forum LCD/Display
    Last Post: 05-05-2004, 09:12 PM
  4. Replies: 5
    Last Post: 02-28-2004, 12:45 PM
  5. 7" LCD screen color loss problem
    By vladilen in forum LCD/Display
    Last Post: 10-04-2003, 03:42 AM
