Results 1 to 10 of 11
Thread: 10.4 open frame lcd kit
    May 2004
    Texas
    I found a distributor that would sell me this lcd kit with usb touch sceen for 650.00 plus shipping , the kit does come with the controller and inverter everythig you need to connect to your pc
    the brightness can be changed by request up to 700 nits
    Technical Specifications
    Module Type: TFT Digital
    Type: Transmissive
    LCD Mode: Color
    Temperature: Medium Extended Temperature
    Backlight: CCFLx2
    Dot Format: 640*RGB*480
    Operating Temperature: 0 to 60
    Storage Temperature: -20 to 70
    Luminance: 380
    Contrast Ratio: 500:1
    Mass: 540g
    Interface: TTL I/F
    Vertical Viewing Angle: -45/55
    Horizontal Viewing Angle: +-60
    Viewing Direction: 12:00
    Outer Dimension: 243.0mm (W) x 181.6mm (H) x 12.2mm (D)
    What type of controller? 640 x 480 is a little on the small side. 600x800 is the lowest I would go
    May 2004
    Texas
    the controller is a Prisma 10 RGB-Video it can handle xga resolution of 1024x768
    the reason I asked is the distance from the controller to the lcd has to be small. If it's a pci/agp controller then the whole computer will have to be close to the lcd
    May 2004
    Texas
    actually the controller is mounted on the back of the lcd on a detachable plate ,the controller has a short cable that goes to the lcd then it has a vga input for the pc cable
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    The controller looks nice. But, as mentioned, the panel is only 640x480. Can they supply panels that are 1024x768, or at least 800x600? What would be the price difference?
    May 2004
    Texas
    from what i understand the Pixel Format: 640(H) x RGB x 480(V) dots, but i believe it supports Resolutions of up to 1024x768 thru the controller. i will check with the dist. on that
    May 2003
    SE Michigan
    Yeah, but displaying 1024x768 on a 640x480 LCD is not going to look good. IMHO, the native resolution is the only resolution that looks good enough to me.
    May 2004
    Texas
    you are correct
    May 2004
    Texas
    Quote Originally Posted by eCarô
    yes they do have a lcd kit with 800X600 for about 650.00 but its only 350 nits
  1. EBAY: Amulet Easy GUI 5.7" LCD Starter Kit
    By sumit_b in forum Classified Archive
    Last Post: 04-02-2004, 09:55 AM
  2. ebay 10.4 touchscreen lcd any good?
    By ryanerb in forum LCD/Display
    Last Post: 10-05-2003, 02:05 PM
  3. Sharp 10.4 LCD Screen with Touch Screen
    By Awol][ in forum General Hardware Discussion
    Last Post: 09-06-2000, 10:30 PM
  4. Sharp 10.4" Touchscreen LCD panel
    By Cameron in forum General Hardware Discussion
    Last Post: 08-20-2000, 04:19 AM
  5. Did I get a Good Deal? 10.4" LCD ?
    By eljefe in forum General Hardware Discussion
    Last Post: 03-18-2000, 09:45 PM
