Results 1 to 10 of 17
Thread: TM-701L converted Lilliput causes radio interference
    Mar 2004
    Vancouver, BC, Canada
    I have a 7" Lilliput that I converted to fit in a DigitalWW in-dash pull out housing. When I did the conversion I used a ribbon cable to replace all of the power/vga/video/touchscreen cables in the housing.
    I have just got my screen in my 2000 VW Jetta and I have noticed that when the screen is on I get static on some radio stations on my head unit. Some stations are fine, others I get no reception. If I turn the screen off radio reception is back to normal on all stations.
    I have tried unplugging everything individually so I know it is the screen. Some refresh rates on the LCD are better than others for radio reception.
    My guess at the moment is that because I am using unshielded ribbon cable the VGA signal may be causing radio interference.
    Anyone know of a filter or something I could put on my radio, or have any ideas? I don't really want to replace all the wires inside my housing, and I know I could just get rid of my head unit and get a USB radio.
    Maximum Bitrate Rundell's Avatar
    I have the same exact problem. Didn't realize it until I read this post, thought that maybe it was something else going on with the radio. I just tested it and it does interfere. I have a slightly different device. I have a IN-720 In-Dash with the Lilliput. I used the original ribbon cable on the IN-720, which is not shielded.
    Please someone help us!
    Thanks!
    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
    GET PAID TO SURF THE INTERNET
    Low Bitrate TommieG's Avatar
    Mar 2004
    Norway
    It can cause interference to GPS's, too.
    Read this thread:
    http://www.mp3car.com/vbulletin/gps/28728-epia-m10k-lilliput-gps-blocker-post226190.html
    Tom
    VIA EPIA M9000/120 GB/Xenarc 700TSV/Opus 90W DC-DC
    Haicom GPS/3Com 11g Wi-Fi/D-Link BT
    WinXP/myHTPC/InfoMap Navigator Eu/PhoneControl w/T68i
    Blaupunkt HU & speakers/Velocity active subs/Alpine amps
    Progress: removed while waiting for nano-itx
    May 2004
    Quote Originally Posted by TommieG
    Read this thread:
    http://www.mp3car.com/vbulletin/showthread.php?p=226190
    Tom
    Bah!!
    I did have the same problem with the GPS but I got it working. from my post on the other thread:
    I could not get a lock no matter what. Right now I can tho. I have it plugged into the front of the morex case and used a USB extension and ran it to the back of my car, top corner of window. Now I can get a lock.
    Newbie lucho's Avatar
    May 2004
    i grounded my vga cable, fixed all problems
    I had interference on my lilliput, I grounded the vga cable that connects to the lillput vga and it fixed my flickering and also my noise.
    Lucho
    Epia M1000, two 80 GB Hard Drives, Lilliput 7" TS, 512 MB DDR, 300 Watt Power Inverter with Relay, Wireless USB Adapter. Routis 2004, Copilot 2003, Rayming TN-200 USB GPS in a 1999 Isuzu Rodeo
    How did you ground the cable? Cut into the cable, and grounded the shielding?
    Quote Originally Posted by lucho
    Lucho
    Just to clarify, sorry don't completely understand what you meant. I don't get any extra noise, like if I’m on Aux on my head unit complete silence, no feedback noise. I get interference on the radio stations. Are you referring to the noise were talking about on the radio?
    May 2004
    sorry
    misunderstood your post. I will try to figure it out for you. If you turn the monitor off, does the radio work normal?
    Yeah when the screen is turned off the radio is clear and works perfect. Turn the screen on again and the radio gets interference where you can barley hear the music
  1. Replies: 2
    Last Post: 06-20-2004, 12:10 AM
  2. lilliput interference?
    By robiewp in forum Input Devices
    Last Post: 06-01-2004, 06:23 AM
  3. Calling all TM 701L users with GPS
    By fyleow in forum LCD/Display
    Last Post: 01-26-2004, 02:28 AM
  4. lost my lilliput cig adapter.. radio shack equivalent part?
    By pogue1000 in forum General Hardware Discussion
    Last Post: 01-06-2004, 07:02 AM
  5. TM 701L Owners
    By chut in forum LCD/Display
    Last Post: 10-08-2003, 03:08 PM
