Results 1 to 4 of 4
Thread: xenarc vs Lillipu (size)
    Jan 2004
    Sweden
    I know the Lilliput vs Xenarc is old. But I think I have a new question on it.
    I want to know how much the xenarc builds under and over the LCD screen. (not together).
    I have a Lilliput but its a little bit to big under the screen so it can't fit in my car. I have to rotate it 180 deg (with Pivot). But I don't like pivot as it takes a lot of CPU.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    The external casing on the Lilliput is smaller than the external casing of both the older and latest generation Xenarcs. The Lilliput I borrowed fit behind my dash with about 3-4mm each side, the new Xenarc was a perfect fit, and the older Xenarc was about 2-3mm too big either side.
    As for screen sizes, I can't help you there, I haven't taken apart the Lilliput or newer Xenarc, and didn't measure the older Xenarc when I had it apart.
    Hope this helps a little
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Jan 2004
    Sweden
    Do you have the new xenarc available?
    Can you meassure how high the frame is under the screen?
    By the way. Have you heard anything from Powerloc about destinator 3 SDK?
    Aug 2003
    Essex, England
    You mean from the bottom of the visible screen to the bottom of the casing? If so, then I can get those measurements for you in hopefully a couple of days
    Unless they've sent something to my work email address in the past week and a half, then nope, I haven't heard anything from PowerLOC
    Garry
    www.aimee.cc
  1. Xenarc direct cause of audio noise- help!
    By shidarin in forum LCD/Display
    Last Post: 04-19-2008, 10:53 AM
  2. What size barrel plugs for Xenarc 730tsv and Audigy NX 2?
    By Mears in forum General Hardware Discussion
    Last Post: 08-29-2005, 06:26 PM
  3. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 07:38 AM
  4. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
  5. Xenarc 7" Touchscreen VGA Group Buy.
    Last Post: 07-27-2002, 11:52 AM
