I had many problems with the original drivers... then got new ones from digitalww.com. Fixed all my problems.
God damn it. I lost my lilliput driver CD.
Hi guys any solution pls..![]()
I am using &' lilliput with Win XP pro. Installation is fine and xp works fine . but my lilliput touch screen stops working after 1 or 2 mts. I have tried to upgrade to Ser. pack 1 and also the driver for the touch scree. but still the same.
So I switched over to Win 2000 and things work fine .( last 29 hrs or so )
The only prob is i want to use XP and not 2000 ( as this is slow and Tweaks dont make much speed ups )
Any Solution as how to get it working with XP![]()
Thanx but i have tried this driver too using a fresh installation of XP and the driver from Digital . but still the same !!!
You said you installed SP1, um...did do do the REST of the Critical Updates?!
well all of them... but the funny part is when i use win2000 it works fine. its only that with xp the touch part is not working...and win2000 is pretty slow to boot and ready for work.. since tweaking is not very effective...
I'm running Windows XP Pro SP1 and everything works fine for me. The computer that it's running on at the moment is my server so it hasn't had a monitor since initial setup. I plugged the LCD in and I could see.
Brainstorm: Did you hook up the USB cable before putting in the driver? Alot of stuff (my MP3 player and the Extigy are the same) need to have the driver installed before plugging in the reboot (restart for best results first). After the driver is installed then the computer should be able to use the device. I would remove the driver through device manager, disconnect the TS, install driver, reboot, then plug in the TS.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
I would also recommend what is stated here. Right click on My Computer and go into device manager under USB devices and check for a splat (Yellow exclamation point). If there is a splat, remove the device, uninstall the drivers and reboot. Reinstall the drivers and install the touchscreen USB adapter. If all is well it should work.Originally Posted by d_sellers1
I have had USB devices shat my whole HDD because I installed it before installing the drivers.
Hi Well tried this stuff alreay. theres no yellow Splat !. and Well let me re phrase the problem. The LCD works fine .. its the touch part that stops responding in a few seconds. Have even tried to disable the ps2 mouse( just in case it has aconflict with touch screen ) but of no help. and while in th same config. of machine and win 2000 the touch part works endlessly..... now where do i stand ???
