I soldered a cable to the outside of the vga connector to a ground in the car. Fixed the issue with my flickering.
Try just holding a cable to the outside of your vga cable and touch a ground wit the other end. It should stop them lines.
Luis
My lilliput screen in my car has static lines that run horizontally. I believe it is wired to the battery and across the ignition (I had it and the opus installed at an auto store). How can I remedy this?
2004 Freelander HSE | Lilliput 7" VGA Touchscreen| Via M10000 | 256 MB | 120 GB | DVD player | TN-200 | Opus 150watt |Windows XP Pro | Media Car | Routis & Destinator
Luis
Epia M1000, two 80 GB Hard Drives, Lilliput 7" TS, 512 MB DDR, 300 Watt Power Inverter with Relay, Wireless USB Adapter. Routis 2004, Copilot 2003, Rayming TN-200 USB GPS in a 1999 Isuzu Rodeo
I believe that this is a common problem with screens. Mine also does this at the moment, I think mine is due to noise or inpropper grounding at the moment. Will let you know what I did to cure it.
The outside of the VGA cable? Not the 9-pin wire, but after the USB and VGA slit at the end of the cord? Then the metal trapezoid?
Try hooking the power up to the output of the Opus rather than direct to the battery.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
I found that when I turn the key to accessories and the computer boots, there is no static. Once I turn the engine the static returns.
Yep, this is because the engine is causing noise in your electical system. Hook the screen up to the regulated output from your Opus, and all the lines will disappearOriginally Posted by nibix
Garry
www.aimee.cc
yes, the actual casing around the 15 pins, try it and let me know.
Luis
Oh cool, I thought it was because of an oversupply of voltage. I'll try this tip also, just need to find a ground point.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Check it out?!
Before I try Confused's suggestion (being that it would mean quite a bit of work) I would like to try lucho's suggestion. Is there any way to groud the wire other than connecting it to the frame? The reason being, I would like to test this before I go ahead and install such a setup. Is there something I could use to ground it just to test it?
