Results 1 to 5 of 5
Thread: Desperately need help getting Xenarc v2.0 and Epia M1000 configured
    Feb 2004
    Ok, I'm pulling my hair out. For some reason I can't do anything with my M1000's onboard graphics to get it to display correctly on my Xenarc 700tsv. I've tried just about every resolution and played with my dpi settings, but all I can get is an image that leaves black bars, an image that overflows the screen, or no image at all so I have to reboot. FYI, I have the refresh rate set at 60hz. Any help would be appreciated.
    ***EDIT***
    I should also mention that I am using the latest s3 unichrome drivers posted on viaarena
    May 2004
    I went into the display settings and chose list all modes under the advanced tab. I then selected 800x600@75hz.
    Works for me.
    Feb 2004
    Under list all modes, all my resolutions are listed at 60hz. I tried selecting and enabling from there using 800x600@60hz and after applying my monitor blacked out again.
    Variable Bitrate brooksware2000's Avatar
    May 2004
    Minot AFB, ND
    Quote Originally Posted by Mears
    ***EDIT***
    Go into your bios setup and look around (I can't remember where it is at but I think its in integrated peripherals) and make sure that you have CRT + LCD selected or just LCD. That may help with the display problem.
    Feb 2004
    Ok, so don't dl the unichrome drivers for cle266 at via arena. I dl'd a driver that feb posted in some other post and it allowed me to set it at 800x600@75hz which works. However, it still doesn't work at 800x600@60hz which is confusing to me.
  1. Epia M Tv-Out & Xenarc
    By az1324 in forum LCD/Display
    Last Post: 02-18-2004, 08:32 PM
  2. EPIA M1000 TV out black border problem.
    By Rudical in forum General Hardware Discussion
    Last Post: 01-19-2004, 04:34 PM
  3. Beware of look alikes- EPIA M1000
    By gizmomkr in forum General Hardware Discussion
    Last Post: 10-31-2003, 06:32 AM
  4. eBay: complete setup, Xenarc, Epia M1000 etc
    By guitar333 in forum Classified Archive
    Last Post: 09-08-2003, 08:21 PM
  5. Epia M and Xenarc
    By az1324 in forum General Hardware Discussion
    Last Post: 08-20-2003, 11:32 PM
