Results 1 to 10 of 17
Thread: Question for STARFOX or anyone else about PSONE LCDs
    Jan 2004
    I just had a quick question about H-sync and it's role in this mod. I wired mine wayyy back when target had them on clearance for $30. Today I was looking at it and noticed for some reason that I had included the wire for H-sync...Do I need this connection? I have a G200 PCI capable of C-sync, could this connection interefere with stuff? I've noticed some have gotten a little clearer image than me, so I am trying to attain perfection
    Cliff notes
    1. I added a H-sync wire
    2. I have a G200 with C-sync enabled and working
    3. Could this hurt/help? (Hsync)
    4. Thanks for reading
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    I found the best quality improvement I got was by applying the 4.7k resistor mod in this thread: http://www.diy-tronic.de/forum/viewtopic.php?t=644
    The one posted by Metallhuhn at 8:18am on Friday May 7th.
    The picture got a whole lot brighter and clearer with this mod.
    Jan 2004
    Quote Originally Posted by Rob Withey
    Thanks! I dunno if I should keep the 3 GNDS tied together or just use a DCC signal wire now...but I will keep experimenting as I have some time before I put it all together
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    If your video card is putting out CSync on the VSync pin, and your HSync pin is still connected, just disconnect it. It might cause some image degredation, but you probably won't noticed it that much.. You're better off to ensure that the shielding on your VGA cable is good.
    What did you want to do with DCC? DCC is a ~5V signal line, it's not a ground.
    Jan 2004
    Quote Originally Posted by starfox
    holllly COW. that H-sync pin caused some crazy degredation! once I disconnected it the image improved a ton! I was confused with what to do with the DCC pin, I see now that it's not what I thought.
    On a side note, when I tried the german 4.7k resistor trick, I lost all red, and the images were practically inverted color-wise??? any insight on this?
    Jan 2004
    got it upright now
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    ahhahhaha that is exactly how I did my PSOne by extending the inverter power cable to have the screen stand up
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Apr 2000
    Bedfordshire, UK
    Thought you might be interested in seeing what I'm up to with this.
    I have removed the audio circuitary, the RGB switch, the aux-video sync separator, and the pass thru video amp. I think I have found the main sync separator for the main input, which if bypassed (and removed) would remove the need for the 74LS86 based sync combiner for non composite out cards. Currently I have the sync combiner glued to the other side of the board (PSX mod chip stylee) and powered internally.
    Additionally I have found a simpler way of performing the always on mod and have applied the 4.7k redness/brightness hack.
    A scan of my board atm:
    May 2002
    Australia
    Yay cool, post more. A friend's been hassling me to trace the composite sync through to where it splits back into hsync and vsync, but i never really had the patience (or a good enough soldering iron) to desolder SMD stuff
    Jan 2004
    I need help on the brightness/redness mod. It seems everyone that has done it has a diff pcb than me. Here are 2 pics, can someone chop them and tell me where to solder the resistor?
    TIA
  1. Another PSOne Mod question. Looked but no answer!
    By Learic in forum LCD/Display
    Last Post: 06-27-2004, 02:02 AM
  2. newbie question about LCDs
    By Hagakure in forum LCD/Display
    Last Post: 02-02-2004, 11:37 AM
  3. Replies: 19
    Last Post: 01-10-2004, 02:22 PM
  4. noob question - how are LCD's measured
    By nodeel in forum LCD/Display
    Last Post: 11-25-2003, 03:08 AM
  5. new computer project... question about ebay LCDs...
    By nadir_s in forum LCD/Display
    Last Post: 10-19-2002, 05:23 PM
