Results 1 to 10 of 11
Thread: 7" Touch Panel Armen sells
    Low Bitrate PHiLiSO's Avatar
    Oct 2003
    detroit
    I ordered the 7" panel armen sells for my broke *** Lilliput but its too big anything I can do to get it to fit? Or do I have to ship it back and get a special Lilliput Touch Panel, anyone know?
    Low Bitrate riuster's Avatar
    Jul 2004
    NYC
    just get the xenarc and be done with it.
    Oct 2003
    detroit
    thats not an option. I have the lilliput custom installed into my dash. I need a new touch panel not a 400 dollar monitor.
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    If you can fit it, just put it on anyway. If the touchscreen overlaps the lcd, it's no big deal. You can calibrate it with the 4 pt or 25 pt test so that it works correctly.
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    What program do you use to calibrate it?...does it come with the cd tha armen includes?
    DICE Los Angeles
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    @yunusyu
    yeap be on the CD. Also inclcuded in the drivers that can be downloaded from various web sites.
    Search mp3car.com for a link for it
    Oct 2003
    detroit
    I know I can calibrate it, but when I insert the touch panel into the housing it hits the plastic where the screws screw in. so I would have to shave those off? Then how will the screen stay together?
    Oct 2003
    detroit
    anyone?
    Jun 2003
    Chester Springs, PA
    Quote Originally Posted by PHiLiSO
    If the panel is larger than the lcd, then it's probably not going to fit in the housing. If this is installed in your dash, do your still need the lcd housing. My lcd and touch panel are out of the case and installed in my 2din dash opening.
    Oct 2003
    detroit
    its installed in the dash but the front housing is fiberglassed in. Wish armen would let me know.
  1. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  2. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 12:54 PM
  3. Touch screen panel ST-070A-01
    By terrastudios in forum LCD/Display
    Last Post: 04-13-2004, 02:00 PM
  4. Screen shots of the TM-702L. Why would you go VGA?
    By audrenaline in forum LCD/Display
    Last Post: 01-12-2004, 04:24 AM
  5. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
