hack apart a cat 5/6 network cable and use that, but good luck this is a tricky thing to get right and remember its not just the signal there will probably be some type of back light as well
Hi,
So i ve been reading on the forums on extending a laptop screen and I think i can start with mine. I have many issues though. The ribbon connecting the motherboard to the laptop screen has ripped so i need to replace it. I was going to use wires and try to solder them because then I can extend the screen too. Also the connection to the mobo has come off, I was going to solder the wires straight to the mobo. Good idea/ bad idea? What kind of wires do i need to use and where can i get them.
Thanks,
A total noob
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
cat 5 will work something sheilded would be better though! Hack apart a monitor extention cable.
[COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
I'm interested in knowing more about extending the lcd, Do you guys know if there is a FAQ or thread that covers this in more detail? Thanks,
c4shm0ney
sorry for the lack of detail, I'm wanting to extend a LCD from a Toshiba Satelite 470CDT about 2 feet and mount it on the dash. I'm curious to know if anyone has done anything with the 470CDT or similar models. From what I've gathered the inverter needs to be kept very close to the lcd, Does anyone where it's located on my model? Correct me if I'm wrong but if the inverter is in the plastic moulding for the lcd then I only need to extend the cable going to it and the power?
Unrelated question.. I'm curious to know if anyone has a good simple and cheap method of attaching a LCD to a car dash?
Thanks for your help,
c4shm0ney
'Ballin on a budget'
what size and type is the screen? It usually makes a difference for the interface pinouts.
this might help others, this is what I have found so far:
you have a SatellitePro 470CDT
with:
Display Type: TFT Active Matrix Color (800 X 600 resolution)
Size 12.1” Diagonal
Dot Pitch .30mm x .30mm
Contrast Ratio: 100:1 (min)
VIDEO
Memory: 4Mbit EDO DRAM, 3.3V 2 MB
Speed: 50ns
Hyper Page mode support: Yes
Controller Chip: C&T F65555
Data Bus Width: 64-bit
PCI Bus Architecture w/burst mode Yes: 32-bit, 30 MHz
Graphics Accelerator: Yes with 64-bit BitBLT support
full specsheet is here
spare parts here
http://www.sparepartswarehouse.com/t...A1255U-T2C.asp
and here
http://www.impactcomputers.com/toshi...-hardware.html
from that last site it looks as if all you have to do is cut the "LCD HARNESS - P000236180" and extend it about the 2 feet that you want and also note the picture of the "Toshiba 12.1" TFT COLOR LCD DISPLAY" it looks as if it has another two wires that will need to be extended.
oh yeah, the Toshiba Part Number for the screen is: P000218950 and/or VF0168P01
sorry
that is all I can do right now I am leaving work, but that should be enough to get you some help
