Results 1 to 10 of 18
Thread: I have 7" TFT but picture is not sharp?
    Jul 2004
    Okay, i have Via Epia 533 computer and 7" TFT monitor in car.
    Monitor picture is not very sharp. Via Epia setting program is not
    good, i cannot get more sharp. Anybody know good program to
    adjust tft monitors settings?
    edit: When computer starting all text is very sharp and can read
    very far (BIOS POST). But when windows is running picture is not
    sharp. Font change give little help, but not enough....
    Newbie Skorpion's Avatar
    Jun 2004
    Melbourne, Australia
    maybe its due to cleartype in windows? its supoosed to make text better on lcd's, but maybe not in this case?
    -right click desktop > properties > appearence > effects (or something, a button) > second option
    could be that you are running at the wrong resolution, is the monitor vga? if not then it's going to be fuzzy anyway, but you could try either 800x600 or 640x480
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    Try unplugging and reconnecting the round plug for the SVGA connector (if you have the Lilliput) - the connector is poorly designed and if it is not tight it will look fuzzy. Also make sure that the VGA connector itself is tight. I had this same problem briefly during installation of the screen, a quick tightening of the connector solved it. The POST text looked clear even with the screen looking fuzzy in windows, I think it is because it is low res to begin with.
    Jul 2004
    I use Via Epia "RCA" tv-out.
    Jul 2004
    What res you use whit lilliput 7" tft? I don`t have lilliput but same size 7".
    There are picture: http://www.huuto.net/auctionimages/f...cc410-orig.jpg
    Jun 2004
    The North, Manchester
    i also getafuzzy pic from the EPIA RCA out, cant use the serial either cos theconnection is super weirdtothe screen!
    no help at all i know,,,,
    On2
    Feb 2004
    NYC
    Quote Originally Posted by tomi667
    There's your problem. RCA out is TV resolution. There's no way you can make the image crisp. They will always be fuzzy cause those screen are around 320 resolution, interlace to 640. I don't know if XP will go that low, but if you want to improve your image a little bit, lower your resolution to 640 and below. Anything higher will be fuzzy image.
    The reason why text is readable during bootup is probably the is booting with low resolution.
    This is the price you pay for cheaper non VGA monitor.
    Variable Bitrate euro320i's Avatar
    Apr 2003
    Near Frankfurt
    Exclamation
    Sorry Tomi,
    with the RCA out you don't get the VGA[FONT=Arial Black]
    resolution. Use that monitor for the back passengers movies.
    For yourself get a Lilliput....
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
    Jul 2004
    Okay, i have to use Via Epia s-video out? If this working,
    thanks for you!
  1. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 04:19 PM
  2. Replies: 55
    Last Post: 12-03-2006, 08:57 PM
  3. Replies: 2
    Last Post: 01-17-2003, 11:16 AM
  4. Probs with picture size on TFT
    By felix99 in forum LCD/Display
    Last Post: 06-17-2002, 05:56 AM
  5. WTB: sharp tft LCDs that are smaller than 7"
    By leon in forum Classified Archive
    Last Post: 01-02-2002, 02:05 PM
