Results 1 to 6 of 6
Thread: Lilliput software help???
    Jul 2004
    Orlando
    Question Lilliput software help???
    I just got my Lilliput 7" TS (noob) but I can't seem to be able to install. When I tried to install the software XP hangs/freezes up at the end of the install. I looked around the forums and tried to update XP and get the drivers from digitalWW. But nothing. I get an image on the screen but I cant get the TS to work. Any help would be greatly appreciated.
    BTW I am running the screen on my Toshiba laptop w/ XP home right now...if that helps.
    Just getting started...
    Alpine CDA-7995, Toshiba 5205-S503, Lilliput 7" Touchscreen
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    You probably have a com port conflict, try removing other devices that use a com port and then install the t/s first particularly remove any bluetooth devices often the bluetooth devices conflict with the ts
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    FS = MTSVO motorised in dash screen pm me for details
    Low Bitrate Shayughul's Avatar
    Jul 2004
    Minot, ND
    Completely remove everything that you have installed....delete all the files you have put on there and then go download and install the latest touchkit from this site.
    Drivers Here
    I had the exact same issue that you are talking about and after a little bit of time on I found these and they work great.
    Hope it helps
    Jul 2004
    Orlando
    Thanks guys Ill try that out today
    Newbie FoxRunner's Avatar
    Dec 2003
    Smile
    Wow I had the same problem...
    Im no expert but this worked for me...
    Like it was already said. Remove ever thing including the drivers you also probably installed.
    Turn the Puter off
    Then hook up just the vga cord to the PC...
    Boot it up
    Using the software form the link provided in the other thread run just the Setup .exe
    Towards the end when it searches com ports.. it took forever. Give it time.
    Get a beer or something. (every one knows it waits untill your not looking to finish up... )
    Hit ok and all stuff
    The program loaded and you plug in the touchscreen/
    Install the driver from the same folder I chose the last one.
    And it worked.
    Jul 2004
    Orlando
    Thanks guys I got it working now
    But.... one problem, I can't seem to play DVDs through XP's media player. It shows up on the laptop but not on the lilliput. What do you guys suggest? A different player? Or different settings? Anybody have suggestions on good DVD software?
    Thanks again guys.
  1. epia m10k + lilliput => gps blocker?
    By NaFooEsi in forum GPS
    Last Post: 04-12-2008, 09:53 PM
  2. cursor jumps around with lilliput software
    By chris in nh in forum LCD/Display
    Last Post: 09-26-2006, 07:28 AM
  3. myHTPC Software
    By the_new_guy in forum Software & Software Development
    Last Post: 06-05-2004, 04:51 PM
  4. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 01:54 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
