If you have a pretty good background in electronics and signals, you may be able to figure out what is going to the monitor. I am going to assume that there is a ribbon cable on the inside that connects the screen, if you can figure out what the interface is (vga/rca), and what the pin-outs are, then you may be in businiess. This will let you use the unit as a monitor. The touchscreen would be pretty hard to hack, because is most likely has an interface that has nothing similar to USB. So you may be able to find a 7" lcd touchpannel, and install it. Look at digitalww for the touch pannel.
I dont have the background in electronics and signals....yet...so i really cant help you out much. Good luck, if you could get it to work it would be very sweet.
-Plinkey
LinkBack URL
About LinkBacks
