Results 11 to 20 of 21
Thread: anyone use CASKA??
  1. #11
    Jun 2004
    The North, Manchester
    do you get good pic with your Caska- if so which model is it and does it fit in DIN HU space??
    On2
  2. #12
    FLAC djmickyg's Avatar
    Feb 2004
    its the one with a 7" screen and a tv tuner
  3. #13
    Jun 2004
    confirmed with manufacter you are 100% correct other cables are not used and res is not enough for PC,
    do you use yours powered by PC?? if so is the pic good?
    Thanksfor all your help mate
  4. #14
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    Mate i nearly bought a caska too with the intention of using the TV OUT (RCA) connection that comes out of my EPIA TV out on my motherboard but like you said the picture quality is crap! a few people on here will tell you the same thing DONT! use tv out even the best tv out chipsets such as the Mobil Radeon by ATI that give crystal clear tv out signals are **** for CAR PC uses the text will look blurry the refresh rate will be annoying the gps information will be too distorted to see! its all too much bother if i had gone through with the caska purchase the one that looks super cool with the blue backlite or the new on with the tv etc i wouldve ended up buying a lilliput rippling the lcd from it and trying to graft it into the caska housing.
    as for the connections you refrering too the PS2 in commonly known as a mini din the PS2 part is purely for the mouse only! not the keyboard alough they look the same.
    the older type was just a din plug as for how many pins count them!! on the caska like the others have said proberly that socket is for a rear view camera or something not for vga, vga is a 15 pin D Type connection that carries clock pulse (Sync) Red Green & Blue data plus numerous GNDS and other signals i doubt you could wire that to the DIN plug your referring too hope this helps!
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
  5. #15
    Jun 2004
    Bit late now......
    Selling to mate for use with his in car DVD.
    SO then.... what is the best in-dash, motorised folding out 7" (ish) screen available that has top pic quality and is VGA???
    your help is mega appreciated!!
    Cheers mate
    On2
  6. #16
    May 2002
    Essex, UK'er
    Quote Originally Posted by OriginalNick2
    Bit late now......
    Cheers mate
    On2
    None yet! not motorised, there are cages / caddys that allow you to fit a lillput into a single din and pull it out manually!, were all waiting here for such a product! its a touchy subject mate!
    www.aimee.cc
  7. #17
    Feb 2004
    ive only used mine sofar with the inbuilt tv tunner and the picture is pretty good on that..
    but i havent yet install my computer setup. its all waiting there eger to go in.. so im not sure how it will look.
  8. #18
    Jun 2004
    could you power it from the computer and let me know???
  9. #19
    Feb 2004
    yeah i will do it soon at get back to u.
  10. #20
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    Wow I got this OLD 5 inch Mobile Authority LCD panel and I just connected it to the TV OUT on the EPIA and it shows like a dual monitor setup but it is ASTOUNDINGLY BLURRY. I am wondering if any of the players could play a video in this monitor like offset the image??? Then the monitor could be for rear passengers watching while I use the Lilliput as a regular carputer. It will probably be too snailey though!!!!
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
  1. Just bought a Caska LCD
    By kore in forum LCD/Display
    Last Post: 11-24-2003, 03:15 PM
