try to change the refresh rate (something low) in the display properties. You might also want to change the resolution to 800*600.
Deleted
If I were you, I'd return my screen and get a different one. If it still does it, at least you'll know it's not the screen.
I had a problem with the first Xenarc I got, similar to your problem, without the error messages.
I just sent it back. :P
If you send it back they'll test it and fix or replace it. I think I got mine back in like a week or so. You have to fill out a form and send it to Xenarc first.
95 Chevy G20 Vroom Boom Room
...with a whole bunch of nifty ****... go check it out: VanDomain Page
I had a similar problem. It was the touchscreen controller. Only way to fix it is to replace it.
If the screen is still under warranty I guess not much harm done ey? good luck with the new screen!
try this link also: http://www.mp3car.com/vbulletin/sear...earchid=380794
If that link is expired, search the LCD/display forum for the words "eeprom" and "touchscreen". Its a common problem![]()
