Results 1 to 6 of 6
Thread: Hot glue + xenarc inverter == unhappy.
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    So I was just opening up my xenarc to reseat some connections, and the hot glue holding the speaker in place had attached itself to a component on my inverter, causing it to be torn off the board as I removed the back.
    So now I need a new inverter. A GS-INV940 to be exact.
    Anyone know where I can get one, anow how much they would cost? More importantly, Does anyone have one I can get within the week. I really need my screen functional. as I use it for work.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Can you just reattach the component?
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Any way to get a pic, can't you just solder the part back on?
    Constant Bitrate JayKaye's Avatar
    Jan 2004
    Sydney, Australia
    ouch!
    www.ti.com (texas instruments)
    I did a search in TI, found nothing. I did a google search, again found nothing. Might be an idea to take the part to your local electronics warehouse an as someone there for a suitable replacement. Sounds to be like it isnt your average part (or part number).
    Car PC v1 - 1999 - 2000
    DOS 6.22 - MPXF - 2x16 LCD - 6.4GB
    Car PC v2 - 2002 - 2006
    XP - 7" wide/touch - GPS - Tank batt relay - 100GB
    Car PC v3 - 2008
    XP - 7" wide/touch - GPS - 802.11g - FM/XM - OBDII - WWW
    [||||||||||||||----] 80% complete
    Jul 2003
    Fremont, CA
    it's pretty ugly. I believe it was an inductor that got pulled off and it didn't even come off clean. I'll show it to my housemate whoes an electrical engineer. If anyone can fix it, he can. If he can't, I've already contacte DScustoms to see if I can't buy a new inverter card.
    Jul 2003
    Fremont, CA
    Update! The inductor I tore off was custom wound. There's no way to reattach it. I need a new inverter. Does anyone out there have a xenarc with a broken screen or something I can canabilize?
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  2. Hot glue is evil.
    By fluffy2097 in forum Input Devices
    Last Post: 07-28-2004, 09:44 AM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  4. Hot glue in PCI slots
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-16-2001, 10:59 AM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
